DC/DC converter advice
I'm new to amateur electronics, but getting there slowly...
I have a requirement for a decent -5v rail. Specifically this is to trip a 4052 mux/demux into analogue mode.
I've since tried a simple 555 based inverter and only scraped -3.6v from the 5v arduino power pin thanks to a pretty inefficient circuit.
I then stumbled across these guys:
http://www.rapidonline.com/Electrical-Power/Power-Supplies/DC-DC-Converter-ICs/1W-Dual-output-DC-to-DC-converters-RVFM/72607
The only one that rapidonline stock is a 24 vin -> 12vout ... Rather annoyingly the picture boasts a G01-04D (5Vin -> ±5Vout) which is exactly what I need. But they don't stock them. Nor can I find anywhere that does!
My question is, is there a cheap alternative, or is anyone aware of a UK-based reseller that sell individual units??
PS, I know about the MAX764s, and at £4 a pop, it's not too friendly.
It sounds like you only need a small current. A cheaper charge pump inverter would be the Microchip TCM829 (<$1) if you're OK with surface-mount devices, or the Microchip TC7660 if not (still <$1). It's part number 9762680 at Farnell and only £0.55!
The Aussie Shield: breakout all 28 pins to quick-connect terminals
It certainly looks like what I need! :slight_smile:
Until this moment, I'd never even heard of a charge pump.
I'll be ordering a couple of those next week then. Thanks for the help!
I know this is starting to now get into the realms of not for this forum, but last question(s), honest! :smiley:
Obviously I need -5V from the +5V, but I know you don't get anything for free!
  1. Will the nearly -5V that I will get from the charge pump IC be good enough for VEE on the HC4052? (Datasheet: http://www.datasheetcatalog.org/datasheets/320/446419_DS.pdf)
  2. I recognise that I'm only going to get close to -5V if the ESR is low on the flying and output caps. I found some 0.06ohm 10uF 25V on farnell that I wonder would do the job?
Thanks for the help this far guys!
Should be fine on both counts.
The Rugged Motor Driver: two H-bridges, more power than an L298, fully protected
I'm switching unamplified audio signals.
In fact, I'm still very much learning, so it's entirely possible I've got this completely wrong and the HC4052 VEE need only be a small negative voltage. I'm honestly not sure.
The datasheet states that VEE is the negative supply. And that VCC - VEE can be 2V - 12V which seems to suggest that my -3.6V will do the trick. I'm not seeing the significance of applying a negative voltage other than to trigger the analogue behaviour. Does the switched signal need to sit in the range VCC to VEE??
If you have a source to scrounge old computer motherboards, many of them had -5V DC-DC converters on them. Look for a large black epoxy box with 4 leads. I have a couple of those in my parts bin.
