DC geared motor with encoder
Hi!!
I have to run a DC geared motor with an encoder and get the feedback of the postion/ number of rotations.
I am using a L298N Dual H-Bridge to run the motor and found some pieces of codes on the net to get something out the encoder but the problem is that I get some false results, for example : after measuring the rotations I can easily see that the motor have turned one time and less than a half and the monitor shows 2250 pulses and for my case i have 810 pulses per main shaft revolution wich gives me 2.77 rotations...
Links :
Attached :
  • schematic
  • Arduino code i am using
Any help will be appreciated!
Thanks
Cheikhna
sketch_apr30a.ino (1.74 KB)
Your encoder outputs are to pins 2 and 3. Why do you read the state o pins 9 and 10 when they fire.
Please post your code inline with code tags like this. More peoiple will look at it.
const int interuptG = 0;
const int interuptD = 1;
const int canalBG   = 9;
const int canalBD   = 10;
int set1 = 6;
int set2 = 7;
int enable = 5;
void Reagir();
void ReagirBis();
long comptD = 0;
long comptG = 0;
//double tourGauche = comptG/1620.0;
//double tourDroite = comptD/1620.0;
  // Permet un affichage du résultat sur la consol Série
  pinMode(set1, OUTPUT);
  pinMode(set2, OUTPUT);
  pinMode(enable, OUTPUT);
  pinMode(canalBG, INPUT);
  pinMode(canalBD, INPUT);
  // Déclaration des intéruptions
  // Ici les fonctions d'intéruptions s'éxecutent
  // sur fronts montants : RISING
  attachInterrupt(interuptG, Reagir, RISING);
  attachInterrupt(interuptD, ReagirBis, RISING);
  delay(4000);
  avancer();
  Serial.print("Tour Gauche");
  Serial.print(comptG);
  arreter();
  reculer();
  Serial.print("   Tour droite");
  Serial.println(comptD);
  arreter();
  comptD=0;
  comptG=0;
void Reagir()
  if(digitalRead(canalBG) == HIGH)
    comptG--;
    comptG++;
void avancer()
       digitalWrite(set1, LOW);
       digitalWrite(set2, HIGH);
       analogWrite(enable, 255);
       delay(5000);
       digitalWrite(set2, LOW);
void reculer()
       digitalWrite(set1, HIGH);
        delay(5000);
void arreter()
  delay(5000);
void ReagirBis()
  if(digitalRead(canalBD) == HIGH)
    comptD ++;
    comptD--;
