I have DC motor 24 V with elliptical gear, specification in attachment.
So, DC motor speed is linear to voltage which I generate with PWM.
I need slow motion for robotic arm movement and position control with encoder.
But at 8% of nominal voltage motor is noisy, sounds weird and do not even really move. I am afraid to damage a motor as it was quite expensive.
I am wondering if there is any minimal voltage for DC motor with gear to operate?
Is it problem with a motor or a gear?
Is there any danger for a motor at a such a low speed?
You want to implement a position control loop with your motor right? You’ll need a PID loop to control
output to the motor, using error between desired position and current position (as provided by the encoder).
Low speed is not a problem, position control loop does that for you (once tuned).
However you have backlash in the gears to worry about - placing the encoder on the motor shaft
won’t compensate for the backlash (but will be stable and can use a lower resolution encoder), encoder
on the output shaft automatically compensates for backlash but you might have stability issues.
