Hi, I have this problem, I think it is so easy but I can't understand where is the difference between the working code and the not working code.
The first work for everything but not for DC motor, Code 2 does not working instead, why?
Codes are the same, I wrote the Code 2, when I saw it workes I do copy and paste on Code 1.
Code 1 :
[code]
#include <MobaTools.h>
#include <Servo.h>
// Define servo motor
Servo Servo1;
Servo Servo2;
Servo Servo3;
const byte enablePin = 8; // for my CNC shield stepper enable
const int stepPin = 12; // a-stp // stepper 4
const int dirPin = 13; // a-dir
int ang1 = 40;
int ang2 = 100;
int ang3 = 90;
// Motore DC
int dir1PinA = 11;
int dir2PinA = 10;
int speedPinA = 9; // Deve essere un pino PWM per essere
//in grado di controllare la velocità del motore
int speed = 100;
int speed2 = 1;
int val;
int ka = 5;
long stepPos = 200;
//Define stepper motor
MoToStepper StepperX(stepPos, STEPDIR);
//MoToStepper StepperY(stepPos, STEPDIR);
MoToStepper StepperZ(stepPos, STEPDIR);
MoToStepper StepperA(stepPos, STEPDIR);
//Define Pin DC motor
pinMode(dir1PinA, OUTPUT);
pinMode(dir2PinA, OUTPUT);
pinMode(speedPinA, OUTPUT);
//Define Pin Stepper
pinMode(stepPin, OUTPUT);
pinMode(enablePin, OUTPUT);
pinMode(dirPin, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
//Define servo initial angle
Servo1.write(ang1);
Servo2.write(ang2);
Servo3.write(ang3);
StepperX.attach(2, 5);
//StepperY.attach(3, 6);
StepperZ.attach(4, 7);
StepperA.attach(12, 13);
StepperX.setSpeed(5500);
// StepperY.setSpeed(5500);
StepperZ.setSpeed(5500);
StepperA.setSpeed(5500);
StepperX.setRampLen(1);
//StepperY.setRampLen(1);
StepperZ.setRampLen(1);
StepperA.setRampLen(1);
if (Serial.available())
val = Serial.read();
if (val == 'y') {
ang1 += ka;
Servo1.write(ang1);
Serial.println('y');
if (val == 'h') {
ang1 -= ka;
Servo1.write(ang1);
Serial.println('h');
if (val == 't') {
ang2 += ka;
Servo2.write(ang2);
Serial.println('t');
if (val == 'g') {
ang2 -= ka;
Servo2.write(ang2);
Serial.println('g');
if (val == 'u') {
ang3 += ka;
Servo3.write(ang3);
Serial.println('u');
if (val == 'j') {
ang3 -= ka;
Servo3.write(ang3);
Serial.println('j');
//Adding stepper motor comad
//Stepper 4 (arm3) A
if (val == 'f') {
StepperA.doSteps(stepPos);
Serial.println('f');
if (val == 'r') {
StepperA.doSteps(-stepPos);
Serial.println('r');
//Stepper 3 (arm2) Z
if (val == 'd') {
StepperZ.doSteps(stepPos);
Serial.println('d');
if (val == 'e') {
StepperZ.doSteps(-stepPos);
Serial.println('e');
//DC Motor
if (val == 'w') {
Serial.println('w');
analogWrite(speedPinA, speed);//Imposta la velocità via PWM
digitalWrite(dir1PinA, LOW);
digitalWrite(dir2PinA, HIGH);
if (val == 's') {
Serial.println('s');
digitalWrite(dir1PinA, HIGH);
digitalWrite(dir2PinA, LOW);
if (val == 'x') {
Serial.println('x');
analogWrite(speedPinA, speed2);//Imposta la velocità via PWM
//Stepper 1 (base) X
if (val == 'q') {
StepperX.doSteps(stepPos);
Serial.println('q');
if (val == 'a') {
StepperX.doSteps(-stepPos);
Serial.println('a');
[/code]
Code 2:
[code]
// Motore DC
int dir1PinA = 11;
int dir2PinA = 10;
int speed = 100;
int speed2 = 1;
int val;
if (Serial.available()) {
if (val == 'w') {
if (val == 's') {
if (val == 'x') {
[/code]
