I want to use small DC motor as a tachometer. The output of the motor is about -5 to +5 V and 1 A, if I'm measuring that correctly. How do I connect the tachometer to the Arduino so that I can safely measure it's output voltage?
I've found two solutions, but I don't understand them. One is to use two half-bridge rectifiers, one to measure positive voltages, and one for negative. I've tried making that, but didn't succeed. How would this circuit look like? Where exactly do I connect tach outputs and where is is Arudino ground and adc?
Another solution is to use a voltage divider and 'add' the voltage to the tach output. I've found that the motor starts drawing current from the arduino if I connect it that way, so I suspect some diodes are needed, but I don't know how.
Yes that is what I was describing. That will let you count pulses from your tacho. However if you want to get an average DC voltage to measure then you need a capacitor across that resistor.
If the voltage from the motor exceeds 5V peak, then you need that resistor to be a potential divider with the arduino fed from the center point ( analogue in ) with the arduino ground connected to the lower connection.
do I need to limit the current from the motor
No because the circuit will only be drawing as much current as that resistor demands by ohms law.
Ok, I can get this to work with only one direction of the motor, either positive or negative. If I want to to measure both negative velocity and positive velocity, I get very weird results on the voltmeter. From your post I figured I need two circuits like that one pictured, each for one direction of current, and then I would read potentiometer wiper outputs with arduino.
I can't find anything on google, but that might just mean I'm using wrong terminology.
