I am planning to monitor the speed of a DC motor (Maxon DCX 12V) with an incremental rotary encoder welded onto the shaft (1024PPR). I am using the VNH5019 Pololu Dual motor driver shield and pin 3 as my encoder input. I am trying to use TIMER2 as a timer interrupt to calculate the speed of my motor (I can't use TIMER1 since pins 9 and 10 are used by the shield to drive the motor). I can get a reading from 'count', however, the speed returns a value of 0.
I feel like the motor is spinning too fast for my code even at a low speed because I keep getting random values for trigger_counter (i.e. the trigger_counter can't keep up with the rotor speed). I have also attached the datasheets for the motor, encoder and the shield. I appreciate your help.
#include "DualVNH5019MotorShield.h"
DualVNH5019MotorShield md;
volatile int count = 0;
volatile int trigger_counter = 0;
volatile int pulse_width = 0;
volatile int previous_count = 0;
volatile double speed = 0;
volatile double pwm_val = 0;
const uint16_t timer_load = 0;
const uint16_t timer_compare = 128000;
Serial.begin (115200);
pinMode(3, INPUT);
attachInterrupt(1, motor_speed, RISING);
md.init();
// initialize timer2
TCCR2A = 0;
TCCR2B |= (1 << CS22); // 1024 prescalar set to 1,1,1 for timer 2 to
TCCR2B |= (1 << CS21); // increment prescalar every 128000 counts
TCCR2B |= (1 << CS20);
TCNT2 = timer_load; // preload timer 2 with the value 0
OCR2A = timer_compare; // store the matched value into the timer 2 register
TIMSK2 = (1 << OCIE1A); // enable the compare interrupt
sei(); //enable global interrupts
md.setM1Speed(50); // set the speed of motor (0-400)
Serial.print("\t Speed = ");
Serial.println(speed);
ISR(TIMER2_COMPA_vect){ //add 1 to the value of count with each increment of the prescalar
TCNT2 = timer_load;
count = count + 1;
void motor_speed(void){
if(trigger_counter < 50) trigger_counter = trigger_counter + 1; //calculates speed every 50 triggers of the encoder
else{
pulse_width = count - previous_count;
previous_count = count;
speed = pulse_width * (1024/50) * 60 / 1000000;
Maxon DCX 32L.pdf (204 KB)
Pololu Dual VNH5019 Motor Driver Shield User's Guide.pdf (1010 KB)
