DC Motor Control and Sensors
Hi
I am quite new to the world of Arduino but have tried already a few things. I have an RC car with a 7.2V DC motor and one servo that I would like to control with arduino. My plan is to get the arduino motor shield from oomlout. That shield can control 2 big motors and 4 servos.
and also an ultrasonic range finder. I have a 3000mah 7.2V NiMh battery that I am planning to connect to the motor shield and also I am thinking to have a 9V battery supply to the Arduino. Do you know if I will have enough pins left to add more sensors or should I be looking at other shields? Initially I would like to add only one range finder at the front but at some point add one in the back too. And maybe look at accelerometers later on. But if I have used all my pins for the motor shield then what are my options?
Thanks in advance
Dimitri
Typically, motor shields only need 4 pins - two for direction and two for speed - to control 2 motors.
Can you post a link to the shield that you intend to get?
Range finders only use one pin.
hello,
If you have choosen this shield :
http://www.oomlout.co.uk/motor-shield-for-arduino-kit-p-207.html
have a look on the code example to determine the pins you really need for your application (a library is available for this shield)
gozaki
www.laboelectronique.be
Hi
thanks for the replies. Yes I have chosen the shield from the oomlout website, unfortunately I cant put the link in here. So from what you say I can put the sensors on the board underneath the motor shield. Excuse my ignorance but I have only played with the arduino board, I havent tried a shield yet and wasn't sure if practically I can plugin the sensors underneath any shield. Programmatically I should have no problems I am an experienced programmer.
Dimitris
Do you know the ratings of this motor (running and stall current)? I have a feeling that if this motor is anything like other r/c car motors running at 7.2VDC, its going to pull way more current than the L293 on that motor controller can supply. For example:
http://www.robotshop.com/gws-rs-777-dc-motor.html
This motor may be similar to yours; it pulls 700mA while running, 21.2 amps stalled; the L293 on that shield can only supply 1.2A of current max (bridged mode, possibly needing a heatsink).
You need to find out -first- how much current your motor draws in both conditions; then you can decide on a motor driver. For higher current drivers, check out Pololu; there's also other options (if you can find a brushed DC motor controller for R/C cars - not airplanes - they can be fairly inexpensive)...
:slight_smile:
Hmmm ok I am a bit concerned now. Here is the link for the motor my rc car has http://www.etamiya.com/shop/tamiya-53689-tamiya-540j-tamiya-motorjohnson-p-4833.html
Any other recommendations for a motor that I can use with this shield?
Dimitris
Hmm - that's kinda low on details...
Current Consumption at Best Efficiency: 7.9A at 7.2V
What that generally means is that at it will pull that much current while running, but that number is -not- the stall current, nor is it the "free running" (no load) current. The stall current is going to be much higher, and the no-load running current lower (probably around an amp or 2) - this sheet here is pretty close:
As you can see, you're probably looking at about 35A when stalled, so you want a controller that can at least handle that, and probably around 8-10A under normal running conditions.
You might be able to get away with something like this:
Especially if the dual outputs could be bridged together for more current handling (not sure if they can).
This controller might be ideal:
http://banebots.com/pc/ELECTRONICS/BB-1245
It used regular RC servo signals for control, and isn't too expensive.
Here's another that would probably be OK:
http://www.dimensionengineering.com/SyRen25.htm
Here's another possibility:
As you can see, there's a wide variety of choices out there - plus none of them are particularly cheap (some of them I consider inexpensive, given what they are doing - high-power h-bridges are easy to design).
The kinds of motors that you use with that kind of shield (or more precisely, the L293 h-bridge chip) tend to look like this:
http://www.tamiyausa.com/product/item.php?product-id=75026
You typically see these shields incorporated to drive a dual-track "tank-like" device like this one:
http://www.tamiyausa.com/product/item.php?product-id=70104
In other words, small hobby motors that may only pull several hundred milliamps when stalled; needless to say, these motors won't work for your application (unless you want to scale down the size of your vehicle)...
:slight_smile:
ok so this shield is for quite "small" in power motors. I am using arduino uno so ideally I would like to connect a motor shield on that. I will have a better look on your recommended controllers just in case I can connect them to arduino.
Thanks anyway
Dimitris
Hi again,
I had a look at my Tamiya TEU-101BK speed controller and it can output Max. continuous current at 60A Forward and 60A Reverse. Any ideas as to which shield I can use with Arduino?
D
well..what do you need sheilds for ? if you want to use the motor controller you won't need a sheild just post a link to waht you want to control with the arduino and we'll get back to you and help :slight_smile:
Yep you are right I found out a few minutes ago that I can just plug in the ESC on arduino like a normal servo and thats all there is to it. Hmmm sorry for the question but I just realized how much trickier I was going to make my project :).
Thanks
D
