Hello, I am new to Arduino and training myself to use its many functions step by step. My project is in the infant stages of an autonomous boat. Right now I am trying to control a motor with keyboard commands. I have successfully done this using serial and processing to move the motor at different speeds and one speed in reverse. Right now my forward speeds 0, 63.75, 85, 127.5, 170, 212.5, 255 and reverse speed 255. My problem comes in to play when I turn the motor to 42.5 the motor just makes a weird sound and doesn't spin and 85 the motor spins with the same noise and again spins at 170 with the noise.
Here is my Arduino code:
char val; // Data received from the serial port
int motorpin = 4; // Wiring: Connect L293D Pin En1 connected to pin PWM 4
pinMode(12, OUTPUT); //Initiates Motor Channel A pin
pinMode(9, OUTPUT); //Initiates Brake Channel A pin
Serial.begin(9600); // Start serial communication at 9600 bps
if (Serial.available()) // If data is available,
val = Serial.read(); // read it and store it in val
if (val == '2') // If '2' was received,
digitalWrite(12, HIGH); //Establishes forward direction of Channel A
analogWrite(3, 63.75); // turn the motor on at 42.5 speed
if (val == '3') // If '3' was received,
analogWrite(3, 85); // turn the motor on at 85 speed
if (val == '4') // If '4' was received,
digitalWrite(3, 127.5); // turn the motor on at 127.5 speed
if (val == '5') // If '5' was received,
analogWrite(3, 170); // turn the motor on at 170 speed
if (val == '6') // If '6' was received,
analogWrite(3, 212); // turn the motor on at 212 speed
if (val == '7') // If '7' was received,
analogWrite(3, 255); // turn the motor on at 255 speed
else if (val == '1') // If '1' was received
analogWrite(3, 0); // turn the motor off
if (val == '8') // If '8' was received,
digitalWrite(12, LOW); //Establishes backward direction of Channel A
digitalWrite(9, LOW); //Disengage the Brake for Channel A
digitalWrite(3, 255); // turn the motor on at 255 speed
delay(100); // Wait 100 milliseconds for next reading
Here is my Processing code:
import processing.serial.*;
import controlP5.*;
ControlP5 cp5;
Serial port;
int KnobValue = 100;
boolean knobOn = false; // Status of the button
boolean firstTime = true;
Knob myKnobA;
Knob myKnobB;
size(480, 480);
smooth();
noStroke();
cp5 = new ControlP5(this);
myKnobA = cp5.addKnob("motorPower")
.setRange(0,255)
.setValue(220)
.setPosition(135,20)
.setRadius(90)
.setNumberOfTickMarks(6)
.setTickMarkLength(7)
.snapToTickMarks(true)
.setColorForeground(color(255))
.setColorBackground(color(0, 160, 100))
.setColorActive(color(255,255,0))
.setDragDirection(Knob.HORIZONTAL)
.setValue(0)
myKnobB = cp5.addKnob("knobDirection")
.setRange(0,255)
.setValue(220)
.setPosition(135,260)
.setRadius(90)
.setDragDirection(Knob.VERTICAL)
println(Serial.list());
port = new Serial(this, Serial.list()[0], 9600);
void draw() {
ellipse(225, 110, 200, 200);
fill(0,100);
ellipse(225, 350, 200, 200);
fill(4,100);
void keyPressed() {
switch(key) {
case('1'):myKnobA.setValue(0);break;
case('2'):myKnobA.setValue(42.5);break;
case('3'):myKnobA.setValue(85);break;
case('4'):myKnobA.setValue(127.5);break;
case('5'):myKnobA.setValue(170);break;
case('6'):myKnobA.setValue(212.5);break;
case('7'):myKnobA.setValue(255);break;
switch(key) {
if (keyPressed) {
if (key == '1') {
port.write('1');
if (keyPressed) {
if (key == '2') {
port.write('2');
if (keyPressed) {
if (key == '3') {
port.write('3');
if (keyPressed) {
if (key == '4') {
port.write('4');
if (keyPressed) {
if (key == '5') {
port.write('5');
if (keyPressed) {
if (key == '6') {
port.write('6');
if (keyPressed) {
if (key == '7') {
port.write('7');
if (keyPressed) {
if (key == '8') {
port.write('8');
Any suggestions?
Constructive criticism always welcomed this is my first post.
