DC Motor control
Hi everybody,
I am new to Arduino programming, but have done many of the examples.
My project i quite simple but i have a few issues which i could use some guidance/help to solve.
I try to make a setup where a Pushbutton by activation ramp up a DC motor, which run at full speed until a microswitch i activated, then the motor ramps down and the system should now be ready for a new Pushbutton activation.
In the attached code this is kind of working but:
  • If Pushbutton is kept activated, the ramp up continuous to run (0->255, 0->255…)
  • The same goes for the ramp down, the motor stop at microswitch activation, but if microswitch is kept activated the motor ramp down (255->0, 255->0…)
The microswitch is used as a positionswitch, meaning that it will be high at starting point.
The LED is not used at this point.
My code:
int PushButton = 8;
int PositionSwitch =12;
int Motor = 3;
int LED = 5;
pinMode(PushButton, INPUT);
pinMode(PositionSwitch, INPUT);
pinMode(Motor, OUTPUT);
pinMode(LED, OUTPUT);
// Read state of PushButton
while(digitalRead(PushButton) == HIGH)
// Ramp up Motor speed
for(int x = 40; x <= 255; x++)
{analogWrite(Motor, x);
delay(5);}
if(digitalRead(PositionSwitch) ==HIGH)
// Ramp down Motor speed
for(int x = 255; x >= 0; x–)
delay(5);}
delay(1);
Best Regards
Arthur
In general do not mix up the button reading with other parts of the code as you are doing in
At the top of loop() check the states of the buttons and save the values in variables.
Then use those values to make decisions. Have a look at Planning and Implementing a Program
You probably also need to detect when the switch changes from not-pressed to pressed rather than detect the fact that it is pressed. Look at the state-change detection example that comes with the Arduino IDE
...R
Thanks Robin,
I will take a look at your suggestions.
/Arthur
