DC motor encoder with PID
Hi, I have wrote an code with timerOne library, and my PID is base on Brett Beauregard's library.
#include <TimerOne.h>
#define MotorR_I1     8
#define MotorR_I2     9
#define MotorL_I3   10
#define MotorL_I4    11
#define MotorR_ENA    5
#define MotorL_ENB    6
#define initial_speedr 100
#define initial_speedl 100
#define encoder0PinA 2
#define encoder0PinB 3
volatile double rpmcount=0.0;
bool inAuto = false;
#define manual 0
#define automatic 1
int speed_left;
double Output, Setpoint=48.0,  lastInput=48.0,kp=1.0,ki=0.01,kd=0.01,outMin=45,outMax=100,ITerm;
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  attachInterrupt(0,rpm_fun,CHANGE);
  attachInterrupt(1,rpm_fun2 ,CHANGE);
  pinMode(MotorR_I1,OUTPUT);
  pinMode(MotorR_I2,OUTPUT);
  pinMode(MotorL_I3,OUTPUT);
  pinMode(MotorL_I4,OUTPUT);
  pinMode(MotorR_ENA,OUTPUT);
  pinMode(MotorL_ENB,OUTPUT);
  analogWrite(MotorR_ENA,0);
  analogWrite(MotorL_ENB,initial_speedl);
  Timer1.initialize(1000);
  Timer1.attachInterrupt( Compute_pid );
void Compute_pid()
  if(!inAuto) return;
   double error = Setpoint - rpmcount;
   ITerm+= (ki*error*0.001);
    if(ITerm> outMax) ITerm= outMax;
   else if(ITerm< outMin) ITerm= outMin;
   double dInput = (rpmcount - lastInput)/ 0.001;
   if(error>=0)
   Output =( kp * error + ITerm  - kd * dInput)+45;
   else  Output =- ( kp * error +  ITerm - kd * dInput)+45;
   if(Output> outMax) Output = outMax;
   else if(Output < outMin) Output = outMin;
   lastInput=rpmcount;
void advance(int a,int speed_left)
  analogWrite(MotorL_ENB,speed_left);
  digitalWrite(MotorR_I1,LOW);
  digitalWrite(MotorR_I2,HIGH);
  digitalWrite(MotorL_I3,LOW);
  digitalWrite(MotorL_I4,HIGH);
  delay(a * 100);
void stopRL(int d)
    digitalWrite(MotorR_I1,HIGH);
    digitalWrite(MotorL_I3,HIGH);
    delay(d * 100);
void back(int d,int speed_left)
    digitalWrite(MotorR_I2,LOW);
    digitalWrite(MotorL_I4,LOW);
    delay(d * 100);
void moveForward( )
  speed_left=(int)Output;
  if((Setpoint-rpmcount)>0)
  {setMode(1);
  advance(0,speed_left);
  else if(Setpoint-rpmcount==0)
  Output=0;
  setMode(0);
  { setMode(1);
    back(0,speed_left);
void setMode(int Mode)
    bool newAuto = (Mode == automatic);
    if(newAuto && !inAuto)
        Initialize();
    inAuto = newAuto;
void Initialize()
   lastInput = rpmcount;
   ITerm = Output;
   if(ITerm> 250) ITerm=outMax;
   else if(ITerm< 0) ITerm= outMin;
moveForward();
void rpm_fun()
   // look for a low-to-high on channel A
  if (digitalRead(encoder0PinA) == HIGH) {
    // check channel B to see which way encoder is turning
    if (digitalRead(encoder0PinB) == LOW) {
      rpmcount = rpmcount- 1;         // CW
    else {
      rpmcount =rpmcount  + 1;         // CCW
  else   // must be a high-to-low edge on channel A
    if (digitalRead(encoder0PinB) == HIGH) {
      rpmcount = rpmcount - 1;          // CW
    else {
      rpmcount = rpmcount + 1;          // CCW
 // Serial.println (rpmcount, DEC);
void rpm_fun2()
{ // look for a low-to-high on channel B
   // check channel A to see which way encoder is turning
      rpmcount = rpmcount-1;         // CW
    else {
      rpmcount = rpmcount+1;         // CCW
  // Look for a high-to-low on channel B
  else {
    if (digitalRead(encoder0PinA) == LOW) {
      rpmcount = rpmcount -1;          // CW
    else {
  //Serial.println ( rpmcount, DEC);
I have a huge problem when error from 1 to -1 .
First, my motor barely can move when the PWM decrease to 45,so I set the output from 100 to 45 ,and zero when it reach error=0,but I don't know how to set the output when the error goes to negative, the
motor'speed should act like error>0 except the moving direction is reverse(but the ki term also has accumulated ), should all terms (-1)or only kp term(1-)or something else?
