DC Motor help!!!
Still can not get a dc motor to run in forward and reverse with speed control using a joystick to control both. I’ve searched high and low for libraries but can get any of them to work (I am very new to writing code). I ran the AF_Motor test and the motor runs so i know that the board and the motor are good. This is the code that i have come up with so far, it reads perfect in the serial monitor but the motor still does not turn (or do anything for that fact!!!). starting to get frustrated and need help
#include <AFMotor.h>
AF_DCMotor motor(2);
const int PotPin = A0; // Change this if pot is connected to another pin
int direction = FORWARD; // Where we are going
int speed = 0; // How fast
int potVal = 506; // Current potvalue
// initialize serial communication at 9600 bits per second:
motor.setSpeed(255);
motor.run(RELEASE);
// read the input on the pot:
potVal = analogRead(PotPin);
if (potVal < 506)
{ // Smaller than 512 so we’re going forward
// Map value from pot-range to motorspeed-range
speed = map(potVal, 0, 506, 255, 0);
{ // Otherwise, we’re going backward
direction = BACKWARD;
speed = map(potVal, 507, 1024, 0, 255);
// print out the variables:
Serial.print("Read: “);
Serial.print(potVal);
Serial.print(” direction: “);
if (direction==FORWARD)
Serial.print(“Forward”);
Serial.print(“Backward”);
Serial.print(” Speed: ");
Serial.println(speed); // End of line, so also make it go a line
delay(1); // delay in between reads for stability
Don’t you need some lines like these in your loop() code?
motor.run(FORWARD);
delay(1000); // run forward for 1 second
motor.run(RELEASE);
delay(100); // ‘coast’ for 1/10 second
There you go being technical again....
