DC motor interrupt?
Essentially, I have a Temperature/Humidity sensor and a Real Time Clock module
wired up to the Arduino. The data is then output to a 16x2 LCD screen. When the
humidity reaches 60%+ a DC motor “FAN” is turned on. When the humidity falls
below 60% the fan turns off.
The first thing, when the humidity is climbing to 60; lets say we reach 60, the
motor doesn’t kick in until the next cycle of humidity readings. How would I
achieve an more instantaneous start? an interrupt?
The second thing. The LCD projects the temperature for 3 seconds followed by the time for 3 seconds;
in a sort of cyclical fashion. The goal is to get “live” updates of the humidity as it
changes projected to the LCD( lets say I put my finger on the sensor, the humidity
changes rapidly). The same idea for the seconds. I’m looking for a way to clean up
the code’s loop section a touch. maybe using some counter or millis funciton?..
Im relatively new to Arduino. Please help!!
//LIBRARIES
#include <SimpleDHT.h>
#include <LiquidCrystal.h>
#include <DS3231.h>
//TIMING FUNCTIONS
DS3231 clock;
RTCDateTime dt;
unsigned long startMillis;
unsigned long currentMillis;
const unsigned long period = 500;
//"FAN" USING L293D
#define ENABLE 5 // Motor
#define DIRA 3   // Motor
#define DIRB 4   // Motor
//DHT11 TEMP+HUM.
int pinDHT11 = 2;
SimpleDHT11 dht11;
byte temperature = 0;
byte humidity = 0;
//LIQUID CRYSTAL
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
void setup(){
  startMillis = millis(); // initial start time
  Serial.begin(9600);//initialize serial communication
  // "FAN" OUTPUT //
  pinMode(ENABLE,OUTPUT);
  pinMode(DIRA,OUTPUT);
  pinMode(DIRB,OUTPUT);
  // RTC //
  clock.begin();
  clock.setDateTime(__DATE__,__TIME__);
  // LCD DISPLAY //
  lcd.begin(16,2);
  lcd.setCursor(0,0);
  lcd.print("Temp & Humidity");
  delay(2000);
  lcd.clear();
void Temp(){
  dht11.read(pinDHT11, &temperature, &humidity, NULL);
  currentMillis = millis();
  //Display Temperature Reading
  lcd.setCursor(0,0);
  lcd.print("TEMP:");
  lcd.print(temperature);
  lcd.print("*C /");
  lcd.print(round(temperature *1.8 + 32));
  lcd.print(" *F");
  //Display Humidity Reading
  lcd.setCursor(0,1);
  lcd.print("HUMIDITY:");
  lcd.print("");
  lcd.print(humidity);
  lcd.print("%");
void Time(){
  dt = clock.getDateTime();
  lcd.print(clock.dateFormat("M-jS-Y", dt));
  lcd.setCursor(0,1);
  lcd.print("TIME:");
  lcd.print(clock.dateFormat(" h:i:s",dt));
void loop(){
  Temp();
  Temp();
  Temp();
  Temp();
  Temp();
  lcd.clear();
  Time();
  lcd.clear();
  Time();
  lcd.clear();
  Time();
  lcd.clear();
  // Run "FAN" if humidity is 60% or above
  if (humidity>= 60){
  digitalWrite(ENABLE,HIGH);
  digitalWrite(DIRA,LOW);
  digitalWrite(DIRB,HIGH);
  Serial.println("FAN ON");
  else{
    digitalWrite(ENABLE,LOW);
    digitalWrite(DIRB,LOW);
    Serial.println("FAN OFF");
why are you doing this in your loop?
  Temp();
  Temp();
  Temp();
  Temp();
  Temp();
  lcd.clear();
  Time();
  lcd.clear();
  Time();
  lcd.clear();
  Time();
  lcd.clear();
just don't do that... your LCD has two lines - so display the humidity, display the time (optimization - only if it has changed) and then do your test for triggering the fan or not.
Usually you would trigger say at 60 and turn off at 58 to avoid starting and stopping constantly if you are around 60
