Dear All
I was built a good working DC(wiper) motor position control with encoder in a past.
This sketch allows you to have a multiple positions, but this time I use only 2.
#include <Button.h>
#include <Encoder.h>
const int PWM0 = 6;
const int PWM1 = 5;
const int BTN_MEM_PIN[] = {7,8};
const int READY = 13;
int currentPos = 0;
int newPosition = 0;
int runningSpeed = 0;
long distanceTogo = 0;
Encoder myEnc(2, 3);
long oldPosition = -999;
long targetPosition = 0;
#define ACCURACY 7
#define DEBOUNCE_MS 20
#define PULLUP true
#define INVERT true
#define motorSpeed 255
#define motorSpeed1 70
#define motorSpeed2 30
Button btnPos1(BTN_MEM_PIN[0], PULLUP, INVERT, DEBOUNCE_MS);
Button btnPos2(BTN_MEM_PIN[1], PULLUP, INVERT, DEBOUNCE_MS);
long memPosition[] = {0,0};
pinMode(PWM0, OUTPUT);
pinMode(PWM1, OUTPUT);
analogWrite(PWM0, 0);
analogWrite(PWM1, 0);
pinMode(READY, OUTPUT);
memPosition[0] = 0;
memPosition[1] = -550;
btnPos1.read();
btnPos2.read();
if(btnPos1.wasReleased()) {
Serial.println("btnPos1");
targetPosition = memPosition[0] ;
if(btnPos2.wasReleased()) {
Serial.println("btnPos2");
targetPosition = memPosition[1] ;
long newPosition = myEnc.read();
distanceTogo = (abs(targetPosition - newPosition));
if (newPosition != oldPosition) {
oldPosition = newPosition;
Serial.println(newPosition);
if( newPosition != targetPosition) {
Serial.print("Target/Actual:");Serial.print(targetPosition);Serial.print(" / ");Serial.print(newPosition);Serial.print(" [");Serial.print(abs(targetPosition - newPosition));Serial.println("]");
Serial.println(distanceTogo);
if(targetPosition < newPosition) {
retractActuator();
if(targetPosition > newPosition) {
extendActuator();
if( (targetPosition == newPosition) || abs(targetPosition - newPosition) <= ACCURACY) {
stopActuator();
if(distanceTogo <= 50 ) {
runningSpeed = motorSpeed2;
if (51 <= distanceTogo && distanceTogo <= 150) {
runningSpeed = motorSpeed1;
if(distanceTogo >= 151){
runningSpeed = motorSpeed;
void retractActuator() {
analogWrite(PWM1,runningSpeed);
digitalWrite(READY, LOW);
void extendActuator() {
analogWrite(PWM0,runningSpeed);
void stopActuator() {
digitalWrite(READY, HIGH);
Now I have a new idea to change the encoder on hall effect sensor 360 degrees. My new project is the tool turret for lathe. I need to divide a circle on 8 positions. I find some sketch wich is able to convert analog input from hall sensor on digital(1024).
Summary the things. I need to have 8 buttons. Each button have specific angle like 45, 90, 135 etc.
If I push(or release) a button the dc motor run to target, like in a previous sketch with encoder.
ReadAnalogVoltage
Reads an analog input on pin 0, converts it to voltage, and prints the result to the Serial Monitor.
Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/ReadAnalogVoltage
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue ;
// print out the value you read:
Serial.println(voltage);
Please help to me how can I use the hall sensor instead of encoder.
Thanks in advance.
