I am trying to gradually change the speed of the motor. However, sometimes as the motor speed is increasing the motor reaches a point where it doesnt further increase speed and just starts pulsing. Sometimes this is at full speed and other times at half speed. I have no idea why it does this. So i tried throwing in a delay command but still nothing. Also, i have tried it without the delay command and i still get the same pulsing. the motor controller im using is the polou smco2b. It supports the 127 speeds.Please help. thanks a lot.
* SMC05A Pololu Dual Serial Motor Controller
* Jeremy Bridon <jbridon@psu.edu>
* Anthony Cascone <acascone@psu.edu>
/*** Includes ***/
#include <SoftwareSerial.h>
#include "math.h"
/*** Definitions ***/
#define rxPin 6 // Defines the "recieve" pin for software serial to motor controller
#define txPin 7 // Defines the "transmit" pin for software serial to motor controller
#define resetPin 8 // Defines the reset pin for the motor controller
// Create a special SoftwareSerial for direction communications with the motor controller
SoftwareSerial motorSerial = SoftwareSerial(rxPin, txPin);
int i=0;
/*** Sample Setup Usage ***/
// Set the baud rate of standard serial
// Initialize the motor controller
InitMotor();
while(i<126)
delay(75);
SetMotor(0,i);
i=i+1;
// Public: Initialize the motor controller and unique serial communications
void InitMotor()
// Setup Pins for I/O
pinMode(txPin, OUTPUT); // Serial Transmit Pin
pinMode(resetPin, OUTPUT); // Motor Reset Pin
// Set the baud rate of software serial
motorSerial.begin(9600);
// Reset the motor controller (By setting low then high signals to the resetPin)
digitalWrite(resetPin, HIGH);
delay(10);
digitalWrite(resetPin, LOW);
delay(10);
delay(10);
// Public: Set a speed (0 to 127) and direction (boolean) to a motor
void SetMotor(int motorIndex, int speed)
// Create the packet buffer
unsigned char buffer[4];
// Start byte and device ID byte
buffer[0] = 0x80;
buffer[1] = 0x00;
// Set motor index
unsigned char index = 0;
// Motor number and direction
buffer[2] = 0x00 | index;
// Motor speed
unsigned char targetSpeed = speed;
buffer[3] = targetSpeed;
// Send the packet
SendPacket(buffer, 4);
// Private: Send a packet through the custom serial motorSerial
void SendPacket(unsigned char *buffer, int bufferCount)
for(int i = 0; i < bufferCount; i++)
motorSerial.print(buffer[i], BYTE);
