DC motor PWM MOSFET problem writing code to allow five different speed.
Hi
I'm trying to write a piece of code which will allow me to enter a number from 0-5 on my computer keyboard which will then through the use of PWM select drive my motor at given speed.
//Program by Jeremy Blum
//www.jeremyblum.com
//Test Motor Speed Using a Transistor
//Define Pins
int motorPin = 6;
int motorSpeed = 0;
  //Set the PWM Motor pin as an output
  pinMode(motorPin, OUTPUT);
    byte incomingbyte = Serial.read(); // this is value entered in serial monitor
 motorSpeed = (incomingbyte -48)*51; // subtracting 48 to get decimal value. Multiply by 51 as 255/51 = 5
    analogWrite(motorPin, motorSpeed); // write to the motor pin the motorSpeed
This is for a university project so unfortunately I only have an arduino simulator here at home to test with but I'm having the following problems:
This doesn't seem to drive the motor at the desired speed
It doesn't loop
Also I want to hold the speed selected until a new value is entered how would this be achieved?
Hope this is clear, thank you for your help
How do you know if you only have a simulator?
It doesn't loop
You have one to many closing braces at the end.
By not changing the speed until you have a new byte.
No this reads the buffer if it contains anything or not. You need to use serial available to see if you actually have data to read.
I know because the simulator displays a value next to the output pin. When I used a piece of source code which cycled the motor speed periodically it displayed the expected values.
Ok so something like
 if Serial.available(){
in my void loop should rectify this?
