Hello,
I am working on a project to control a car driven by 2 DC motors with my hand. I attached 2 flex sensors on two fingers of a glove, and depending on each position ( There are four positions: Both unbent, left bent only, right bent only, and both bent) I will send the data to the car using a 315 MHz transmitter and receiver.
On the car, I have a motor shield (L298N) connected to the arduino along with the receiver. Depending on which data is received , the car can go in four directions ( Forward, Right, Left and backwards). Now to make things straight, the receiver is working just fine, my problem is to change the speed of the motors. If I set the speed of both motors to be either 0 or the max of 255, everything works perfect. The problem is that I want to decrease the speed of the left motor when turning right and the right motor when turning left. But whenever I try to do that, the program just stops and the motors lock up on the last value they read.
I double checked all the connections, the PWM pins needed are for enabling the 2 motors ( I am using pins 9 and 10 of the arduino). One more note, I changed the speed of the motors alone, separate from the project and they worked fine. So in short, there seems some problem going on when trying to change the speed inside the receive program.
I have attached a picture of the motor shield and the code for the transmitter and receiver.
Any help!
Thanks in advance
transmit.ino (673 Bytes)
receive.ino (1.25 KB)
