DC Motor Speed Control
Hi, I am controlling DC motor at different speeds using L239D.
3 push buttons triggers to different speeds. This code works perfectly without DC power (12v) to motor. Each button sends the right serial value.
As soon as I connect 12 V, it reaches 255 and serial monitor hangs.
Iteration2.ino (1 KB)
post your schematic too please
I have attached the schematics
Wow big (upside down 8) ) file to open and view....
But, are the Arduino. power and 293 grounds connected together?
:slight_smile:
Yes all the grounds are connected together
Are you sure you have the logic 5V to the right pin on the 293?- you have it shown in the correct place on your drawing, opposite pin 1, but with the wrong number: it's 16 not 9.
Pin is connected to 16 and still I am getting the same error.
As soon as I power up the DC of 12V. Arduino COM ports and motor stops.
Thanks guys all of them. I read lots of topics and i controlled two dc motors.
