DC Motor will not reverse
Hi, I am using a sn754410 H driver and the motor will run forward and respond appropriately to changes in PWM so i am assuming the circuitry is correct.
int speedPin = 3; // h bridge enable pin for speed control
int motor1APin = 6;
int motor2APin = 7;
int ledPin = 13;
int speed_value_motor1;
pinMode(speedPin, OUTPUT);
pinMode(motor1APin, OUTPUT);
pinMode(motor2APin, OUTPUT);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH); //indicator led
digitalWrite(motor1APin, HIGH); // I believe if i inverse motor1Apin and
//motor 2 the motor should reverse... but it's not
digitalWrite(motor2APin, LOW);
speed_value_motor1 = 90;
analogWrite(speedPin, speed_value_motor1);
You might want to post your schematic...
will send the motor in one direction and:-
digitalWrite(motor1APin, LOW);
digitalWrite(motor2APin, HIGH);
will send it in the other direction.
When i set motor1APin = High and motor2Pin = low the motor simply stops running. what could possibly cause this?
Here are the instructions i am following
web.ics.purdue.edu/~fwinkler/616/sn754410_Arduino.pdf
We may need to see a picture of your actual circuit to be able to help as well...
Have you verified that the signals at the pins of the Arduino are high/low for the pins? How about at the h-bridge chip? Are you certain the h-bridge chip is connected properly (here's where a picture would help us - you've given us the schematic, which is good, but we don't know for certain that you followed it completely without seeing your implementation)?
:slight_smile:
Let me know if you can't veiw these
and
as you can see in the first picture i a spare H bridge and i have plugged that one in as well... It performs in the same unsatisfactory manner
