DC Motor with Encoder (keeps giving 0s en 1s)
Hi, I bought this motor:
https://mijn-hebbeding.nl/Webwinkel-Product-212558579/12V%20320rpm%20-%2012V%20107rpm%20--6V-160rpm-DC-Gear-Motor-Encoder-Motor-Met-Montagebeugel-En-Wiel.html
And want to test it out with this library:
And this tutorial:
If I turn it around I only get
0
1
0
1
0
1
In my Serial Monitor. Also it does not matter if I turn clockwise or counter-clockwise.
It should be this:
What should I do to make it count when I am turning it?
Code:
/* Encoder Library - Basic Example
 * http://www.pjrc.com/teensy/td_libs_Encoder.html
 * This example code is in the public domain.
#include <Encoder.h>
// Change these two numbers to the pins connected to your encoder.
//   Best Performance: both pins have interrupt capability
//   Good Performance: only the first pin has interrupt capability
//   Low Performance:  neither pin has interrupt capability
Encoder myEnc(5, 6);
//   avoid using pins with LEDs attached
  Serial.println("Basic Encoder Test:");
long oldPosition  = -999;
  long newPosition = myEnc.read();
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    Serial.println(newPosition);
Try monitoring the encoder's 'A' and 'B' output phases with a DMM as you turn the motor by hand. Do they operate in the expected sequence?
