DC motor with remotexy
HI,
I would like to control my dc motor with slider( front and reverce movement).
Have you got any good solusion???
It is important to use a protection diode.
If you want the motor to drive in both directions you need an H-bridge.
My first thought was to go to the local burger shop for a slider. The slider you refer to I assume is a pot. So get the Arduino cookbook and read it. Also on line there are many videos etc showing the Arduino and how to do what you want. This additional information will go a long way in getting your problem solved. Once you get past this you then need to select your sensors and actuators. At that point you start on the hardware design and write your software.
