DC motor with ultrasonic sensor
So I'm trying to make a device that when the ultrasonic sensor senses something less than 20 cm away, the motor activates. Here is my code:
const int trigPin = 9;
const int echoPin = 10;
const int motor = 7;
long duration;
int distance;
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(motor, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration*0.034/2;
Serial.println(distance);
digitalWrite(motor, HIGH);
I'm now trying to wire the whole thign to my Arduino Uno, but I can't get it to work. Does anyone know a way I could wire this ONLY using wires and a breadboard? BTW the motor requires a tiny amount of voltage to run, so it runs when plugged into the Arduino.
Does the distance measurement work?
You need an [u]if-statement[/u].
What's the current rating on the motor? The Arduino I/O pins are rated for 40mA (0.04A) "absolute maximum". Any more than that and you are over-stressing the Arduino. And, make sure to add a reverse diode across the motor to kill the high voltage [u]back-EMF[/u] when the motor shuts off.
if(distance < 20)
digitalWrite(motor, LOW);
I'm not sure what rating it is but the motor runs fine off a AAA battery. Also, I'm trying not to use anything besides wires, the arduino, the motor, and the sensor because I don't want to spend more money on it, as this is just a prototype, so is there any way to wire it just with wires?
