DC motor wont work with enableA
hey guys,
im working on a project for some time now.
the goal is to use a potmeter to control the output to (pwm) a dc motor and monitor it with a LED bargraph and LCD(i2c). everything works except the motor… the “mSpeed” i use for the PMW is monitord and when i turn the potmeter it goes to 255 and back. is it someting with the code for the L298n driver? for battery i used a 7.5v battery for the L298n and the USB port for the arduino. Thank you!
  #include <Arduino.h>
  #include <Wire.h>
  const int enableA = 5;                                  // pin 5 is the enableA for PWM
  const int in1 = 4;                                      // pin 4 is the in1
  const int in2 = 2;                                      // pin 2 is the in2
  LiquidCrystal_I2C lcd(0x27, 16, 2);
  int ledPins[] = {13, 12, 11, 10, 9, 8};                         // array for the LED`s
  int schakelaar = 7;                                             // Switch forward/backward
  int potMeter = A0;                                              // analog input for the potentionmeter
  int ledCount = 6;                                               // number of LED`s
void setup(){
  pinMode(enableA, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(schakelaar, INPUT);
  lcd.begin(16,2);
  lcd.backlight();
  for(int actieveLED =0; actieveLED < ledCount; actieveLED++){    // making ledPins as outputs
    pinMode(ledPins[actieveLED], OUTPUT);
 digitalWrite(in1, LOW);                    // zeroize motors
 digitalWrite(in2, LOW);
void loop(){
  int sensorVal = analogRead(potMeter);                           // snesorVal gets value from potmeter
    niveauRegeling(sensorVal);
  int statusSchakelaar = digitalRead(schakelaar);
    if(statusSchakelaar== HIGH)                                   // switch to control forward or backward
      PWMcontrolVooruit(sensorVal);
    else{
      PWMcontrolAchteruit(sensorVal);
void niveauRegeling(int sensorVal){
  int ledLevel = map(sensorVal, 0, 1023, 0, ledCount);
  for(int actieveLED= 0; actieveLED < ledCount; actieveLED++)
    if(actieveLED < ledLevel){
      digitalWrite(ledPins[actieveLED], HIGH);
     else{
        digitalWrite(ledPins[actieveLED], LOW);
void PWMcontrolVooruit(int sensorVal){
  int mSpeed = map(sensorVal, 0, 1023, 0, 255);
  int LCDspeed = map(sensorVal, 0, 1023, 0, 100);
    analogWrite(enableA, mSpeed);
    digitalWrite(in1, HIGH);
    delay(50);
    Serial.println(mSpeed);
   lcd.setCursor(0,0);
   lcd.print("ForWard speed:");
   lcd.setCursor(0,1);
   lcd.print(LCDspeed);
   lcd.print(" %");
void PWMcontrolAchteruit(int sensorVal){
    digitalWrite(in2, HIGH);
    delay(50);
    lcd.setCursor(0,0);
    lcd.print("BackWard speed:");
    lcd.setCursor(0,1);
    lcd.print(" %");
Do you have the 7.5V battery negative connected to the Arduino GND?
Have you tested with a basic program that simply writes to the motor to test that the L298 and motor wiring are correct? Post a circuit diagram so we know how you have set it up.
Steve
