Hi
I need to purchase two dc motor that able to caring 15kg each and can get to a speed 8-10 km/h.
Can someone suggest ?
Thanks !!!
Hi
Thanks !!!
Oh, that's easy. Just use any motor you like and add a big gearbox. In worst case use a slope or free fall to achieve desired speed.
What does "able to caring" mean? What does the project look like i.e what are the motors moving/driving/pulling/lifting at 8-10 km/h?
Steve
Can you suggested on one ? I want to install 2 dc and to caring something that have 15kg some times up to 25 kg with 8-10 km/h.
Can you please tell me if this motor is ok for me
BringSmart JGY-370 Worm Motor DC Motor
6/12V 150rpm ?
Hi Steve,
My goal is to build robot with 2 dc motor can pull something
Sometimes its need to pull 15kg up to 25kg
I don’t know which DC motor i need.
Zahi
I've deleted/merged your other cross-post(s) @ZahiTooz.
Cross posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
You are providing almost no useful information. So far I have no idea what you're talking about.
Draw a picture of your 'robot' and the thing it is pulling that weighs 25Kg. Is the 25Kg on wheels or skis? What shape and size is it? Does it need to be pulled up hill? How steep? Across rough ground?
Steve
Ok,
My robot that i want will pull something with wheels i need to build the connection between the robot to the wheel on the same high.
I need my robot will pull another robot on wheel(regular) with 25 kg max.
Im a beginner sorry for that poor information
ZahiTooz:
speed 8-10 km/h.
That's not for the faint-hearted. A 5k run in 30m is a pretty decent "weekend runner" speed.
Motor choice aside, that's going to need some pretty robust controlling.
I didn’t understand which DC motor i need to buy.
Like i say i want to build robot car that will caring other car with regular wheel with maximum 25kg, 15-25kg.
If you're new to this whole Arduino / robotics / electronics etc thing, my advice is put that project on the back burner for a while.
Get a small lightweight robot chassis with a couple of small motors, add a few sensors and get comfortable with the letting it drive back and forward on your driveway.
Something the size of a shoebox and a couple of 100g.
20+kg @ 10km/h will knock someone flying and cause some pain.
Learn with something smaller and safer; unless you're past that stage?
Thanks but i don’t want to build a simple robot i have one of like the simple one with couple of sensors.
I want to build a new one, but i have difficult with the dc motor which size to get the result that i write.
Thanks
Any suggestions?
