I tried ServoTimer2 also. There is a parasitic fact. Why can’t i work those with together?
Here my code;
HardwareSerial &bluetooth = Serial;
#include <Servo.h> // servo library
Servo myservo;
int input='0'; //input to be used
String input2; //variable for string input
myservo.attach(3);
pinMode(A0,OUTPUT);
pinMode(A1,OUTPUT);
pinMode(A2,OUTPUT);
pinMode(A3,OUTPUT);
if(bluetooth.available()> 0 ) // receive number from bluetooth
int servopos = bluetooth.read(); // save the received number to servopos
Serial.println(servopos); // serial print servopos current number received from bluetooth
myservo.write(servopos); // roate the servo the angle received from the android app
if(Serial.available()>0)
input = Serial.read();
// forward
if(input == '1')
digitalWrite(A0,HIGH);
digitalWrite(A1,LOW);
digitalWrite(A2,LOW);
digitalWrite(A3,HIGH);
//back
else if(input == '2')
digitalWrite(A0,LOW);
digitalWrite(A1,HIGH);
digitalWrite(A2,HIGH);
digitalWrite(A3,LOW);
//right
else if(input == '3')
//left
else if(input == '4')
//default state
else if(input == '0')
I also tried any PWM pins.
OM222O
December 25, 2018, 9:21pm
#2
Each function is blocking, i.e. stops the other function. If you want to do "multi threaded programming" per se, you should use the built in timer interrupts which can get very messy, very quickly.
I understand now but i can't figure it out. I try find an other way.
How can I use that timer? There is no other way.
I do. Like this; (Not need timer interrupt)
int input;
Servo myservo1, myservo2, myservo3;
myservo1.attach(3);
myservo2.attach(5);
myservo3.attach(6);
pinMode(A0,OUTPUT);
pinMode(A1,OUTPUT);
pinMode(A2,OUTPUT);
pinMode(A3,OUTPUT);
if(input>=0 && input<180) {
myservo1.write(input);
else if (input == 205) //Gripper Move To Angle 0
myservo2.write(0);
else if (input == 206) //Gripper movw to angle 90
myservo2.write(90);
else if (input == 207) //gripper move to angle 180
myservo2.write(180);
else if (input == 202) //Gripper Move To Angle 0
myservo3.write(0);
else if (input == 203) //Gripper movw to angle 90
myservo3.write(90);
else if (input == 204) //gripper move to angle 180
myservo3.write(180);
else if(input == 241)
//back
else if(input == 242)
//right
else if(input == 243)
//left
else if(input == 244)
//default state
else if(input == 200)
