DC Motors running at different speed!
This is my first self balancing bot. It balances well but there is one problem that one of my motors runs at a slower speed than the other. When I pick my bot up in air it runs visibly slower and when I keep it on the ground it doesn't run at all! I'm guessing it is not able to develop enough torque. I'm using encoder motors but not using the encoder features.
These are the motors I'm using.
Youtube links: Link1 Link2
My code (Not my work :p):
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
//#include "MPU6050.h" // not necessary if using MotionApps include file
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 mpu;
#define OUTPUT_READABLE_YAWPITCHROLL
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
float euler[3]; // [psi, theta, phi] Euler angle container
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
static int pot1Pin = A0;
static int pot2Pin = A1;
static int pot3Pin = A2;
float Kp = 0;
float Ki = 0;
float Kd = 0;
float targetAngle = 0;
float currAngle = 0;
float pTerm = 0;
float iTerm = 0;
float dTerm = 0;
float integrated_error = 0;
float last_error = 0;
float K = 1;
// === INTERRUPT DETECTION ROUTINE ===
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
    mpuInterrupt = true;
// === INITIAL SETUP ===
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
        TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
#endif
    while (!Serial);
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
    Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    Serial.println(F("Initializing DMP..."));
    devStatus = mpu.dmpInitialize();
    mpu.setXGyroOffset(220);
    mpu.setYGyroOffset(76);
    mpu.setZGyroOffset(-85);
    mpu.setZAccelOffset(1788); // 1688 factory default for my test chip
    if (devStatus == 0) {
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(0, dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        packetSize = mpu.dmpGetFIFOPacketSize();
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
    pinMode(4, OUTPUT);
    pinMode(5, OUTPUT);
    pinMode(pot3Pin, INPUT);
    pinMode(pot1Pin, INPUT);
    pinMode(pot2Pin, INPUT);
   // pinMode(A3, OUTPUT);
    pinMode(6,OUTPUT);
    pinMode(7,OUTPUT);
    pinMode(9, OUTPUT); //motor pwm
    pinMode(10, OUTPUT); //motor pwm
// === MAIN PROGRAM LOOP ===
    if (!dmpReady) return;
    while (!mpuInterrupt && fifoCount < packetSize) {
    fifoCount = mpu.getFIFOCount();
    if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
        mpu.resetFIFO();
        Serial.println(F("FIFO overflow!"));
    } else if (mpuIntStatus & 0x02) {
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        fifoCount -= packetSize;
#ifdef OUTPUT_READABLE_YAWPITCHROLL
            mpu.dmpGetQuaternion(&q, fifoBuffer);
            mpu.dmpGetGravity(&gravity, &q);
            mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
            Serial.print("ypr\t");
            Serial.print(ypr[0] * 180/M_PI);
            Serial.print("\t");
            Serial.print(ypr[1] * 180/M_PI);
            Serial.print("\t");
            Serial.println(ypr[2] * 180/M_PI);
#endif
        Kp = map(analogRead(pot1Pin), 0, 1024, 0, 255);
        Ki = map(analogRead(pot2Pin), 0, 1024, 0, 20);
        Kd = map(analogRead(pot3Pin), 0, 1024, 0, 20);
        Serial.print("Kp: ");
        Serial.print(Kp);
        Serial.print("        Ki: ");
        Serial.print(Ki);
        Serial.print("        Kd: ");
        Serial.println(Kd);
        currAngle = (ypr[1] * 180/M_PI);
        Drive_Motor(updateSpeed());
        Serial.print("speed: ");
        Serial.println(updateSpeed());
float updateSpeed() {
  float error = targetAngle - currAngle;
  pTerm = Kp * error;
  integrated_error += error;
  iTerm = Ki * constrain(integrated_error, -50, 50);
  dTerm = Kd * (error - last_error);
  last_error = error;
  return -constrain(K*(pTerm + iTerm + dTerm), -255, 255);
float Drive_Motor(float torque)  {
  Serial.print("torque: ");
  Serial.println(torque);
  if (torque >= 0)  {
    // drive motors forward
    digitalWrite(4, LOW);
    digitalWrite(5, HIGH);
    digitalWrite(6, LOW);
    digitalWrite(7, HIGH);
  }  else {
    // drive motors backward
    digitalWrite(4, HIGH);
    digitalWrite(5, LOW);
    digitalWrite(6, HIGH);
    digitalWrite(7, LOW);
    torque = abs(torque);
  analogWrite(9, torque);
  analogWrite(10, torque);
  //analogWrite(A3,torque);
Please help!
What type of battery are you using to power the motors
Why are you not using the encoders, these would provide your control system with information as to motor position and speed so permitting it to make judgement on corrections.
Encoders are useful for controlling perambulation, but for balance you need torque control, which
is best done using a current feedback loop, since current determines torque pretty well.
I presume you are controlling the motors with PWM output (open-loop), which is partly why they
are behaving differently, since the torque is not being directly controlled.
Usually motors from the same batch would be pretty well matched though, so long as driven in
the same relative direction (many DC motors have deliberately assymetric performance to
improve efficiency in forward direction).
Connect the "bad" motor to the side that is working. Is the motor OK? (Probably is)
Check you wiring again VERY VERY carefully, in particular the connections on Arduino pins 4,5,6,7,9,10 to the motor control board. Make sure the connections are correct and electrically good connections. It looks like you are using low cost wires, sometimes the pins and sockets are not connected to the wire properly. Change out each of the control wires for new ones and test. If you can't see a problem swap the left and right digital control pins over, does the fault change sides?
One of my motor boards like yours had duff solder joints. Check them under high magnification for cracks around the pins.
Secure the wires better, if the bot falls over things can get temporarily shorted out causing failures in the electronics or connections can get broken.
I don't know the code for controlling the motors using the encoders!
shekharsuman:
Knowledge is post learning
Learning is pre knowledge
@bodmer: i'll give that a try!
@jackrae: I reduced the torque to the motor running at higher speed by the factor of 0.9. It is now functioning more like a balancing bot!
analogWrite(9, 0.9 * torque);
A comment about the video you illustrated :
The system was obviously managing to balance itself but the fact that loose devices and wires were flapping around was making the balance task much more difficult - due to a shifting centre of gravity. For good balancing is is essential that the CofG is fixed which means no loose bits flapping in the wind.
Yeah. You're right! I was going to fix that but during my trial run I observed the different running speed of motors. That is why I didn't fix it.
Also do you have any idea what changes should I make to couple my bot with a bluetooth module to make it run forward or backward?
