Dug out an old Uno board to use for a prototype I am working on. Wanting to power it with a DIY'd benchtop PSU however the DC power isn't working, and I am not sure how to trouble shoot it.
Powered by USB all is fine, and thinking back I do recall this being the case. I think at some point I may have plugged both USB and DC power in at the same time.
So, question is, where do I start looking for how to rectify this issue? I am not worried about replacing the dc jack of anything as this board is likely to be hardwired into a powersource long term.
OK... I suspect the regulator is fried. I take it the board works if you put 5 V on the 5V line. The only thing you can check is if you get 5V there when you power from the DC jack.
Do you have + going to the center of the power jack?
With the usb disconnected, and 12 on the jack, what voltage do you measure on the Vin and +5 volt header pins with respect to the GND header pin?
Could have zapped the reverse polarity diode too. With 12V applied, do you measure 12v on the anode side of the diode (back of the barrel jack) and ~0.5V to 0.7V less on the cathode side (Vin pin)?
ChilliTronix:
Yes.
5v pin to ground gives 1v with 5v DC jack
LarryD:
yes
11.69 at Vin, 1.7 at 5+ pin.
CrossRoads:
