I need to control a 500w 36v brushless ebike motor with its controller with an Arduino UNO.
The controller takes as input a 1v-4.2v analog signal (given by a throttle), which I'm willing to control with Arduino 5v digital PWM signal instead of the throttle.
My idea was to step down the signal from 5v to 3.1v with a buck converter and then adding a bias of 1.1v.
Then I thought of putting an MCP4725 DAC, but from my understanding, it converts the signal from 0 to x voltage (am I right?)
You can put a low pass filter on the PWM, that will basically convert it to DC. You could buffer this output using a NPN transistor in the emitter follower configuration. You might want to preload the emitter with a resistor. If you are not using the pins of the Arduino you can make a R2R DAC with a few resistors. There is a lot on the internet about using the resistors as a DAC.
Do you know the PWM frequency ?
step-1: reduce the 5V arduino PWM to 4.2V with a voltage divider
step-2: insert an RC LPF comprised of a 4.7k ohm resistor and a 4.3uF cap between the arduino pwm with the
resistor connected between the arduino and controller and the cap from the resistor on THE CONTROLLER side
to GND.
Write a program to change duty cycle in 55 steps and delay 1 minute to allow you to measure the analog voltage on the cap.
Plot the results in Excel to check linearity.
