Hi guys I want to use a 3.7v lipo battery with 1000mah and use a dc to dc step up to get it to 5v.
What I want to know is what happens to the 1000mah does it stay the same?
Many thanks
M.....
Many thanks
M.....
Yes, but how that relates to your final output is another matter. If the step up is 100% efficient (practically impossible), then the Amp Hours you get at 5 volts will be 3.7/5ths of that at 3.7v. In reality it'll be somewhat less, probably about 90% of that.
Thinking of it another way:
1,000 mAh at 3.7 V is 3,700 mWh
With 90% efficient DC-to-DC converter you will get 3,330 mWh out.
At 5 V your 3,330 mWh becomes 666 mAh.
Thanks for the reply's guys then the battery will work for me because I only need 400mah.
Thanks again.
Undermentioned:
Just as well. Batteries rarely live up to their published Ah rating. If you tried to draw an Amp for a solid hour from a battery rated at 1000mAh It's exceedingly unlikely you'll get it.
