DCF 77 and Time :how to get the digits of hour and minutes
I am 85 years old and a very beginner in programming, but a professional in electronics.
I use a Mega 2560 . I have loaded the DCF- sketch of Thijs Elenbaas and I have connected a Pollin DCF receiver. This all works well, so I get the values of date and time on the console display. Fine !
Now I want to have the separate digits of hour and minutes for my own sketch, but I cannot find the right way to import these values in my own sketch.
Can anyone help me ?
Arie
But we can't see your code.
If you can print them, you can assign them to variables.
Without seeing your code? No.
This is the code of the sketch Thys Elenbaas:
#include “Utils.h”
#include “DCF77.h”
#include “Time.h”
using namespace Utils;
#define DCF_PIN 2 // Connection pin to DCF 77 device
#define DCF_INTERRUPT 0 // Interrupt number associated with pin
time_t prevDisplay = 0; // when the digital clock was displayed
time_t time;
DCF77 DCF = DCF77(DCF_PIN,DCF_INTERRUPT);
DCF.Start();
setSyncInterval(30);
setSyncProvider(getDCFTime);
// It is also possible to directly use DCF.getTime, but this function gives a bit of feedback
//setSyncProvider(DCF.getTime);
Serial.println(“Waiting for DCF77 time … “);
Serial.println(“It will take at least 2 minutes until a first update can be processed.”);
while(timeStatus()== timeNotSet) {
// wait until the time is set by the sync provider
Serial.print(”.”);
delay(2000);
if( now() != prevDisplay) //update the display only if the time has changed
prevDisplay = now();
digitalClockDisplay();
void digitalClockDisplay(){
// digital clock display of the time
Serial.println("");
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print(‘0’);
Serial.print(digits);
unsigned long getDCFTime()
time_t DCFtime = DCF.getTime();
// Indicator that a time check is done
if (DCFtime!=0) {
Serial.print(“X”);
return DCFtime;
There's the function that gets the hour for instance.
You could just:
int someVariable = hour();
And you'd have the hour in a variable.
