Hello!
Help me with code:
(Arduino: 1.6.7 (Windows 10), Плата:“Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)”
C:\arduino-1.6.7\Projects\DCF77_simulator\main\main.ino: In function ‘void timer1_init()’:
main:304: error: ‘OCR1C’ was not declared in this scope
OCR1C = 204;
main:308: error: ‘TCCR1’ was not declared in this scope
TCCR1 = (1<<CTC1)|(1 << CS10) | (1 << PWM1A) | (1 << COM1A1);
main:308: error: ‘CTC1’ was not declared in this scope
main:308: error: ‘PWM1A’ was not declared in this scope
C:\arduino-1.6.7\Projects\DCF77_simulator\main\main.ino: In function ‘void __vector_12()’:
main:335: error: ‘OCR1C’ was not declared in this scope
if (irq_counter&0b00000001) OCR1C=206; else OCR1C=205;
exit status 1
‘OCR1C’ was not declared in this scope at the end)
#include <avr/io.h>
#include <stdint.h>
#include <avr/sleep.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <avr/wdt.h>
#include <stdbool.h>
#define FLAG_TENTH_SECOND 0
#define FLAG_SECOND 1
#define DCF_DATA_SIZE 8
#define DCF_DATA_STARTBIT 20
#define DCF_DATA_MEZ_1 17
#define DCF_DATA_MEZ_2 18
#define DCF_DATA_MINUTE 21
#define DCF_DATA_MINUTE_LENGTH 7
#define DCF_DATA_MINUTE_PARITY 28
#define DCF_DATA_HOUR 29
#define DCF_DATA_HOUR_LENGTH 6
#define DCF_DATA_HOUR_PARITY 35
#define DCF_DATA_DAY 36
#define DCF_DATA_DAY_LENGTH 6
#define DCF_DATA_WEEKDAY 42
#define DCF_DATA_WEEKDAY_LENGTH 3
#define DCF_DATA_MONTH 45
#define DCF_DATA_MONTH_LENGTH 5
#define DCF_DATA_YEAR 50
#define DCF_DATA_YEAR_LENGTH 8
#define DCF_DATA_DATE_PARITY 58
#define INT_TO_BCD(x) ((((x) / 10 )<< 4) + ((x) % 10))
volatile uint8_t flags;
static void timer0_init();
static void timer1_init();
static void portb_init();
static void bit_set(uint8_t* bits, uint8_t bit);
static void bits_clear(uint8_t* bits, uint8_t size);
static void dcf_calculate(uint8_t* dcf_data);
uint8_t bits_data_write(uint8_t* bits, uint8_t data, uint8_t startpos,
uint8_t length);
static uint8_t month_length(uint8_t month, uint8_t year);
int main(void) {
uint8_t dcf_data[DCF_DATA_SIZE];
uint8_t dcf_counter = 0;
uint8_t tenth_second_counter = 0;
bool output_value = false;
bool dcf_data_bit = false;
int i;
wdt_disable();
portb_init();
_delay_ms(1000);
timer1_init();
timer0_init();
sei();
dcf_calculate(dcf_data);
while (1) {
if (flags & (1 << FLAG_TENTH_SECOND)) {
flags &= ~(1 << FLAG_TENTH_SECOND);
//Start of a new Second
//get Data Bit from DCF Data Memory
if (tenth_second_counter == 0) {
if (dcf_data[0] & 0b00000001)
dcf_data_bit = true;
//Shift entire DCF Data Memory 1 Bit to the Right
for (i = 0; i < DCF_DATA_SIZE; i++) {
dcf_data >>= 1;
if (i < (DCF_DATA_SIZE - 1)) {
if (dcf_data[i + 1] & 0b00000001)
dcf_data |= 0b10000000;
//generate output (100 or 200 ms, No output in Second 59)
output_value = true;
if ((tenth_second_counter == 1) && dcf_data_bit)
if (dcf_counter == 59)
//Write output data to Port
if (output_value)
DDRB |= 0b00000001;
DDRB &= 0b11111110;
tenth_second_counter++;
if (tenth_second_counter == 10) {
dcf_counter++;
if (dcf_counter == 60) {
dcf_counter = 0;
return 0;
static void portb_init() {
DDRB = 0b00000010;
PORTB= 0b00000010;
//clear size Bytes in Memory
static void bits_clear(uint8_t* bits, uint8_t size) {
uint8_t i;
for (i = 0; i < size; i++)
bits = 0x00;
//set Bit bit in Memory
static void bit_set(uint8_t* bits, uint8_t bit) {
bits[bit >> 3] |= ((1 << (bit & 0x07)));
//write length bits , starting at startpos to memory
uint8_t length) {
uint8_t i;
uint8_t bitcount = 0;
for (i = 0; i < length; i++) {
if (data & 0b00000001) {
bit_set(bits, startpos + i);
//count 1-Bits for later Parity-Generation
bitcount++;
data >>= 1;
return bitcount;
static void dcf_calculate(uint8_t* dcf_data) {
uint8_t bitcount;
static uint8_t minute = 00;
static uint8_t hour = 8;
static uint8_t day = 11;
static uint8_t weekday = 6;
static uint8_t month = 8;
static uint8_t year = 12;
//initialize Memory
bits_clear(dcf_data, DCF_DATA_SIZE);
//Write Startbit
bit_set(dcf_data, DCF_DATA_STARTBIT);
//Set MET / MESZ
bit_set(dcf_data,DCF_DATA_MEZ_1);
//Write Date/Time Data with Parity to Memory
bitcount = bits_data_write(dcf_data, INT_TO_BCD(minute), DCF_DATA_MINUTE,
DCF_DATA_MINUTE_LENGTH);
if ((bitcount & 0b00000001))
bit_set(dcf_data, DCF_DATA_MINUTE_PARITY);
bitcount = bits_data_write(dcf_data, INT_TO_BCD(hour), DCF_DATA_HOUR,
DCF_DATA_HOUR_LENGTH);
bit_set(dcf_data, DCF_DATA_HOUR_PARITY);
bitcount = bits_data_write(dcf_data, INT_TO_BCD(day), DCF_DATA_DAY,
DCF_DATA_DAY_LENGTH);
bitcount += bits_data_write(dcf_data, INT_TO_BCD(weekday), DCF_DATA_WEEKDAY,
DCF_DATA_WEEKDAY_LENGTH);
bitcount += bits_data_write(dcf_data, INT_TO_BCD(month), DCF_DATA_MONTH,
DCF_DATA_MONTH_LENGTH);
bitcount += bits_data_write(dcf_data, INT_TO_BCD(year), DCF_DATA_YEAR,
DCF_DATA_YEAR_LENGTH);
bit_set(dcf_data, DCF_DATA_DATE_PARITY);
//Count clock
minute++;
if (minute >= 60) {
minute = 0;
hour++;
if (hour >= 24) {
hour = 0;
weekday++;
if (weekday >= 8)
weekday = 1;
day++;
if (day >= month_length(month, year)) {
day = 1;
month++;
if (month >= 13) {
month = 1;
year++;
if (year >= 100)
year = 0;
ISR (TIMER0_COMPA_vect) {
static int irq_counter = 0;
irq_counter++;
//set flag every tenth second
if (irq_counter == 25) {
irq_counter = 0;
flags |= (1 << FLAG_TENTH_SECOND);
static void timer0_init() {
OCR0A = 249;
TCCR0A = (1 << WGM01);
TCCR0B = (1 << CS02);
//enable Overflow Interrupt
TIMSK0 |= (1 << OCIE0A);
static void timer1_init() {
OCR1A = 103;
OCR1B = 0;
OCR1C = 204;
//Timer1 /2
* TIMSK1 |=(1<<OCIE1B);*
//returns lenth of a month
static uint8_t month_length(uint8_t month, uint8_t year) {
if (month == 2)
return (year % 4 == 0) ? 29 : 28;
if (month == 4)
return 30;
if (month == 6)
return 30;
if (month == 9)
return 30;
if (month == 11)
return 30;
return 31;
ISR (TIMER1_COMPB_vect) {
static uint8_t irq_counter;
irq_counter++;
