My apologies if this has been covered before, but I can find no reference to it.
I am developing yet another arduino based DSO, and it has a lot of associated hardware. In order to achieve capture speeds of 2MHz I am using all of PORTD and some asm code.
The issue is this: if I set DDRD=B00000000; in C++ just before jumping into the asm, the port does not seem to be put into read mode - I have to actually do it in the asm.
Here is the method (I'm posting the whole thing for completeness - comments and disassembly follow):
* Use the 16MHz clock to capture at full speed
* @return uint16_t The position in the buffer where the trigger was found
uint16_t ShedScope::captureRAMFastTrigA(uint16_t samples, uint8_t trigger, bool rising)
uint8_t port = PORTC;
uint8_t low = USBEN ;
uint8_t high = USBEN | EXTCLK;
uint16_t start=0;
uint8_t s0 = 0; //register to hold sample history so we can catch a rising/falling edge
bool trig = false;
cli();
PORTC = USBEN | RDN | WRN;
// Set the clock control up for full-speed
setControl(RESET|STOP|CLKSEL0|CLKSEL1);
// Taking ETXCLK high will enable the clock when we are ready
setControl(CLKSEL0|CLKSEL1);
pinMode(0,0);
pinMode(1,0);
DDRD = 0; // This doesn't work for some reason. No idea why. So we do it by hand in the assembler below
__asm__ __volatile__ (
"\n"
"ldi %A[start], 0" "\n\t" // initialise the output register start
"ldi %B[start], 0" "\n\t" // initialise the output register start
"out 0x0a, r1" "\n\t" // Set DDRD by hand
"out %[portc], %[high]" "\n\t" // start the clock
"nop" "\n\t" // nops to pad out the first capture cycle
"cpi %[rising], 0" "\n\t" // nops to pad out the first capture cycle
"breq 7f" "\n\t" // nops to pad out the first capture cycle
// Trigger on rising edge
"1:" "\n\t" // Get even trigger sample
// Next cycle we start to look for trigger rising
"adiw %[start], 1" "\n\t" // A=1, LA1 latched through
"" "\n\t" // A=2, ADC0 available
"breq 6f" "\n\t" // A=3, ADC0 latched through
"2:" "\n\t"
"in %[s0], %[pind]" "\n\t" // A=4, ADC1 available
"nop" "\n\t"
"cp %[s0], %[trigger]" "\n\t" // A=5, ADC1 latched through
"brsh 1b" "\n\t" // A=6, LA0 available
"nop" "\n\t"
"adiw %[start],1" "\n\t" // A=1, LA1 latched through
"breq 6f" "\n\t" // A=2, ADC0 available
"nop" "\n\t"
"cp %[trigger], %[s0]" "\n\t" // A=5, ADC1 latched through
"nop" "\n\t"
"rjmp 4f" "\n\t"
// Trigger on falling edge
"7:" "\n\t" // Get even trigger sample
"8:" "\n\t"
"nop" "\n\t"
"brsh 7b" "\n\t" // A=6, LA0 available
"nop" "\n\t"
"nop" "\n\t"
"nop" "\n\t"
"rjmp 4f" "\n\t"
"3:" "\n\t" // Capture loop
"nop" "\n\t" // nops to make a loop last 8 cycles
"4:" "\n\t" // Entry point when we've already used a cycle
"sbiw %[samples], 1" "\n\t" // 2 clocks
"brne 3b" "\n\t" // 2 clocks if branched, 1 if not
"ldi %[trig], 1" "\n\t"
"rjmp 5f" "\n\t"
"6:\n\t" // Exit when no trigger was found
"ldi %[trig],0" "\n\t"
"5:\n\t"
"out %[portc], %[low]" "\n\t" // disable the clock
: [samples] "=&w" (samples),
[start] "=&w" (start),
[s0] "=&r" (s0),
[trig] "=&d" (trig)
: [portc] "I" (_SFR_IO_ADDR(PORTC)),
[pind] "I" (_SFR_IO_ADDR(PIND)),
[high] "r" (high),
[low] "r" (low),
[trigger] "r" (trigger),
[rising] "d" (rising)
sampleBuffer[0] = s0;
DDRD = B11111110;
// Reset the address counters ready for call to readRam()
setControl(RESET|STOP);
setControl(0);
triggered = trig;
return start;
And here is a partial disassembly:
00000ebc <_ZN9ShedScope19captureRAMFastTrigAEjhb>:
ebc: df 92 push r13
ebe: ef 92 push r14
ec0: ff 92 push r15
ec2: 0f 93 push r16
ec4: 1f 93 push r17
ec6: 8c 01 movw r16, r24
ec8: e4 2e mov r14, r20
eca: f2 2e mov r15, r18
ecc: 88 b1 in r24, 0x08 ; 8
uint8_t s0 = 0; //pair of registers to hold sample history so we can catch a rising/falling edge
uint8_t s1 = 0;
bool trig = false;
ece: 88 e3 ldi r24, 0x38 ; 56
ed0: 88 b9 out 0x08, r24 ; 8
ed2: c8 01 movw r24, r16
ed4: 6f e0 ldi r22, 0x0F ; 15
ed6: 70 e0 ldi r23, 0x00 ; 0
ed8: 0e 94 5d 06 call 0xcba ; 0xcba <_ZN9ShedScope10setControlEi>
edc: c8 01 movw r24, r16
ede: 63 e0 ldi r22, 0x03 ; 3
ee0: 70 e0 ldi r23, 0x00 ; 0
ee2: 0e 94 5d 06 call 0xcba ; 0xcba <_ZN9ShedScope10setControlEi>
pinMode(0,0);
ee6: 80 e0 ldi r24, 0x00 ; 0
ee8: 60 e0 ldi r22, 0x00 ; 0
eea: 0e 94 69 0c call 0x18d2 ; 0x18d2 <pinMode>
pinMode(1,0);
eee: 81 e0 ldi r24, 0x01 ; 1
ef0: 60 e0 ldi r22, 0x00 ; 0
ef2: 0e 94 69 0c call 0x18d2 ; 0x18d2 <pinMode>
DDRD = 0;
ef6: 1a b8 out 0x0a, r1 ; 10
[high] "r" (high),
[low] "r" (low),
ef8: 98 e0 ldi r25, 0x08 ; 8
efa: 8c e0 ldi r24, 0x0C ; 12
efc: ac 01 movw r20, r24
efe: 3f 2d mov r19, r15
f00: a0 e0 ldi r26, 0x00 ; 0
f02: b0 e0 ldi r27, 0x00 ; 0
f04: 1a b8 out 0x0a, r1 ; 10
f06: 48 b9 out 0x08, r20 ; 8
f08: 00 00 nop
f0a: 00 00 nop
f0c: 00 00 nop
f0e: 00 00 nop
f10: 00 00 nop
As you can see, the compiler has generated
For the C++ line
DDRD = 0;
and I have checked that at this point r1 does indeed contain zero (as it should). But without the later hand-coded
DDRD does not seem to go into input mode.
I've mucked about with disabling interrupts in case that has anything to do with it, but no joy.
Does anyone have any clue what is happening here?
Thanks,
Duncan
