Dead chip?
Hi everyone.
I have a problem. I upload my sketches to my arduino mega adk using usbasp programner, because I have burned out the usb chip on arduino. This uploading worked well. Today I was uploading my sketchs as normally, but It took very long time. So I have plugged the programmer out (It still wasn't finished). Then I have plugged it again in and I wanted to reupload the sketch. But there was the first error: BAD CHIP SIGNATURE. I have restarted the arduino and recconected the programmer. But there was the second error: TARGET DOESN'T ANSWER. I have tried everything (check the cable, disconnect all wires from arduino, ...), but it still doesn't work. Is the arduino (or the chip) dead?
Can you help me please?
Thank you very much!
Jakub Horák
Just in case having more information will help getting your issue fixed, please do this:
  • File > Preferences > Show verbose output during: > upload(check)
  • Try an upload
  • After the upload fails you’ll see a button on the right side of the orange bar “Copy error message”. Click that button.
  • Paste the error in a message here USING CODE TAGS(</> button on the toolbar).
Here is it:
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : usbasp
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
One more note: when I connect power to pins Vin and GND Arduino starts weird whistle (on pins + 5V GND not).
PS: Sorry for my english :slight_smile:
