Dead pins
Hi all! How are you?
Working on a proyect with my arduino, i noticed that i have 2 pins that don't work as INPUT (when i bought my arduino they worked), these are A0 and 13, I tested it with the example sketches, in the serial monitor A0 with a variable resistor doesn't change from 1023.
And pin 13 in the serial monitor doesn't change from 1.
But both works as OUTPUT.
Is there any way to fix it?
Greetings ;)
replace atmega-chip.. or accept it
And how i know that the problem is of the chip?
Alferciu: And how i know that the problem is of the chip?
It can't be anything else.
Ok, i will replace it, thanks :) :)
