the servos work
the LED's work properly
and we know that avgX and avgY carry the proper values (from 0 to 179).
I can even run a seperate piece of code that is built just to control the servo that shows the connections are right.
Why then do my servos go dead-fish and simply not respond to this code. It looks so right to me!
ADXL3xx
Reads an Analog Devices ADXL3xx accelerometer and communicates the
acceleration to the computer. The pins used are designed to be easily
compatible with the breakout boards from Sparkfun, available from:
http://www.sparkfun.com/commerce/categories.php?c=80
http://www.arduino.cc/en/Tutorial/ADXL3xx
The circuit:
analog 0: accelerometer self test
analog 1: z-axis
analog 2: y-axis
analog 3: x-axis
analog 4: ground
analog 5: vcc
created 2 Jul 2008
by David A. Mellis
modified 4 Sep 2010
by Tom Igoe
This example code is in the public domain.
// these constants describe the pins. They won't change:
#include <Servo.h>
Servo myservo0;
Servo myservo1; // create servo object to control a servo
int val0; // variable to read the value from the analog pin
int val1;
const int groundpin = 18; // analog input pin 4 -- ground
const int powerpin = 19; // analog input pin 5 -- voltage
const int xpin = A3; // x-axis of the accelerometer
const int ypin = A2; // y-axis of the accelerometer
const int zpin = A1; // z-axis
const int arraySize=9;
int Xled1 = 2;
int Xled2 = 3;
int Yled1 = 4;
int Yled2 = 5;
//statement(s);
int sumX=0;
int avgX=0;
int sumY=0;
int avgY=0;
int xArray[arraySize];
int yArray[arraySize];
myservo0.attach(8);
myservo1.attach(9);
// initialize the serial communications:
// Provide ground and power by using the analog inputs as normal
// digital pins. This makes it possible to directly connect the
// breakout board to the Arduino. If you use the normal 5V and
// GND pins on the Arduino, you can remove these lines.
pinMode(groundpin, OUTPUT);
pinMode(powerpin, OUTPUT);
pinMode(Xled1, OUTPUT);
pinMode(Xled2, OUTPUT);
pinMode(Yled1, OUTPUT);
pinMode(Yled2, OUTPUT);
digitalWrite(groundpin, LOW);
digitalWrite(powerpin, HIGH);
digitalWrite(7, HIGH);
for (int i=0; i<(arraySize+1); i++) {
xArray[i]=0;
yArray[i]=0;
//Shift whole array
for (int i = 0; i < (arraySize - 1); i++) {
xArray[i+1]=xArray[i];
yArray[i+1]=yArray[i];
//take new value
val0 = analogRead(xpin);
val0 = map (val0, 267, 400, 0, 179);
val1 = analogRead(ypin);
val1 = map (val1, 267, 400, 0, 179);
//insert it
xArray[0]=val0;
yArray[0]=val1;
//find average of X
sumX=0;
for (int i = 0; i < arraySize; i++) {
sumX = sumX + xArray[i];
avgX = sumX / (arraySize+1);
//find average of Y
sumY=0;
sumY = sumY + yArray[i];
avgY = sumY / (arraySize+1);
//write to servo
myservo0.write(avgX);
myservo1.write(avgY);
// The following code is just for troubleshooting, it prints a tab between values of in the program
// the values read properly, as the program is intended:
Serial.print("avgX=");
Serial.print(avgX);
Serial.print("\t"); Serial.print("\t");
Serial.print("val0=");
Serial.print(val0);
Serial.print("avgY=");
Serial.print(avgY);
Serial.print("val1=");
Serial.print(val1);
// print a tab between values:
Serial.print("\t");
// Serial.print(analogRead(zpin));
// delay before next reading:
delay(50);
// print the sensor values, and show LEd when past 45 degrees:
if (analogRead(xpin) < 300)
digitalWrite(Xled1, HIGH);
digitalWrite(Xled1, LOW);
if (analogRead(xpin) > 366)
digitalWrite(Xled2, HIGH);
digitalWrite(Xled2, LOW);
if (analogRead(ypin) < 308)
digitalWrite(Yled1, HIGH);
digitalWrite(Yled1, LOW);
if (analogRead(ypin) > 376)
digitalWrite(Yled2, HIGH);
digitalWrite(Yled2, LOW);
