Dead time not working
I’m trying to drive an inverter circuit using the Arduino Due to drive the gate signals of IGBT’s and I need dead time to drive the circuit safely. I tried implementing the dead times and they just aren’t working. Can anyone tell me what I’m doing wrong?
/* This code generates Quasi-Square Waves at 60Hz*/
static byte stateCount = 0;
static float CPRDV = 0;
static float inverterFrequency = 60;
int divA = 42;
  //Serial.begin(57600);
  PMC->PMC_PCER1 |= PMC_PCER1_PID36;                  // Enable PWM (Power On)
  PIOC->PIO_PDR |= PIO_PDR_P3 | PIO_PDR_P5 | PIO_PDR_P7;           // Setting pins 3,5,7 (DUE Pins 35, 37, 39) to PWM Peripheral, not GPIO
  PIOC->PIO_ABSR |= PIO_ABSR_P3 | PIO_ABSR_P5 | PIO_ABSR_P7;       // Setting pins to Peripheral B
  PIOC->PIO_PDR |= PIO_PDR_P2 | PIO_PDR_P4 | PIO_PDR_P6;           // Setting pins 2,4,6 (DUE Pins 34, 36, 38) to PWM Peripheral, not GPIO
  PIOC->PIO_ABSR |= PIO_ABSR_P2 | PIO_ABSR_P4 | PIO_ABSR_P6;       // Setting pins to Peripheral B
  PWM->PWM_CLK = PWM_CLK_PREA(0) | PWM_CLK_DIVA(divA);  // Set PWM clocke rate to 2MHz (84MHz/42)
  PWM->PWM_SCM |= PWM_SCM_SYNC0 | PWM_SCM_SYNC1 | PWM_SCM_SYNC2;      // Synchronizing of Channels 0, 1 and 2
  PWM->PWM_SCM |= PWM_SCM_UPDM_MODE1;                 // Manual Write of duty-cycle automatic trigger of the update
  calcCPRDV();
  /*Serial.print("CPRDV = ");
  Serial.print(CPRDV);
  Serial.print("\n");*/
  PWM->PWM_CH_NUM[0].PWM_CPRD = CPRDV;                // Channel 0 Period f = 2MHz/(CPRD)= 360Hz
  PWM->PWM_CH_NUM[0].PWM_CMR = PWM_CMR_DTE | PWM_CMR_CPRE_CLKA;     // Period is left aligned,clock source is CLKA on Channel 0
  PWM->PWM_CH_NUM[1].PWM_CMR = PWM_CMR_DTE;
  PWM->PWM_CH_NUM[2].PWM_CMR = PWM_CMR_DTE;
  PWM->PWM_CH_NUM[0].PWM_DT = PWM_DT_DTH(0) | PWM_DT_DTL(555);        // Set channel dead-time for 10% 0f CPRD delay on output PWML0
  PWM->PWM_CH_NUM[1].PWM_DT = PWM_DT_DTH(0) | PWM_DT_DTL(555);      // Set channel dead-time for 10% 0f CPRD delay on output PWML1
  PWM->PWM_CH_NUM[2].PWM_DT = PWM_DT_DTH(0) | PWM_DT_DTL(555);
  NVIC_SetPriority(PWM_IRQn, 0);                      // Set the Nested Vector Interrupt Controller (NVIC) priority for the PWM controller to 0 (highest)
  NVIC_EnableIRQ(PWM_IRQn);                           // Connect PWM Controller to Nested Vector Interrupt Controller (NVIC)
  PWM->PWM_IER1 = PWM_IER1_CHID0;                     // Enable interrupt on PWM channel 0 triggered at end of PWM period
  //PWM->PWM_CH_NUM[0].PWM_CDTY = 0;                    // Channel 0 duty-cycle at 0%
  //PWM->PWM_CH_NUM[1].PWM_CDTY = 0;                    // Channel 1 duty-cycle at 0%
  //PWM->PWM_CH_NUM[2].PWM_CDTY = 0;                    // Channel 2 duty-cycle at 0%
  //PWM->PWM_CH_NUM[0].PWM_DT = PWM_DT_DTH(420)| PWM_DT_DTL(420);
  //PWM->PWM_CH_NUM[1].PWM_DT = PWM_DT_DTH(420)| PWM_DT_DTL(420);
  //PWM->PWM_CH_NUM[2].PWM_DT = PWM_DT_DTH(420)| PWM_DT_DTL(420);
  //PWM->PWM_CH_NUM[0].PWM_DT = 42;
  //PWMC_SetDeadTime(PWM, 0, 42, 42);
  PWM->PWM_ENA = PWM_ENA_CHID0;                       // Enable synchronous PWM on Channel 0
void PWM_Handler()                       // PWM Interrupt Service Routine (ISR)
  if (PWM->PWM_ISR1 & PWM_ISR1_CHID0)    // Check if an update condition has occured
    update_Duty_Cycle();                 // Update the duty cycles
void calcCPRDV ()
  //inverterFrequency = 60;
  static float numOfVectors = 6;
  static float adMCKFreq = 84000000;
  static float timerFreq = (adMCKFreq/divA); //2MHz
  static float period = 1/inverterFrequency;
  static float Ts = period/numOfVectors;
  static float switchingFreq = 1/Ts;
  CPRDV = (timerFreq/(1*switchingFreq));
  /*Serial.print("Inverter Frequency = "); Serial.print(inverterFrequency);Serial.print("\n");
  Serial.print("Num of Vectors = "); Serial.print(numOfVectors); Serial.print("\n");
  Serial.print("Timer Freq = "); Serial.print(timerFreq); Serial.print("\n");
  Serial.print("Period = "); Serial.print(period, 8); Serial.print("\n");
  Serial.print("SSV Period = "); Serial.print(Ts, 8); Serial.print("\n");
  Serial.print("Switching Freq = "); Serial.print(switchingFreq); Serial.print("\n");*/
void update_Duty_Cycle()
    if(stateCount < 6)
          PWM->PWM_CH_NUM[0].PWM_CDTYUPD = 0;
          PWM->PWM_CH_NUM[1].PWM_CDTYUPD = 0;
          PWM->PWM_CH_NUM[2].PWM_CDTYUPD = 0;
          stateCount++;
          /*Serial.print("Counter = ");
          Serial.print(stateCount); Serial.print("\n");*/
      static byte count = 0;
      static float p = CPRDV;
      static float n = 0;
      //Serial.print("Sector = "); Serial.print(count); Serial.print("\n");
      switch(count)
          case 0: //pnn = 100 => 012
            PWM->PWM_CH_NUM[0].PWM_CDTYUPD = p;
            PWM->PWM_CH_NUM[1].PWM_CDTYUPD = n;
            PWM->PWM_CH_NUM[2].PWM_CDTYUPD = n;
            PWM->PWM_CH_NUM[0].PWM_DTUPD = PWM_DTUPD_DTHUPD(0)| PWM_DTUPD_DTLUPD(555);
            PWM->PWM_CH_NUM[1].PWM_DTUPD = PWM_DTUPD_DTHUPD(0)| PWM_DTUPD_DTLUPD(555);
            PWM->PWM_CH_NUM[2].PWM_DTUPD = PWM_DTUPD_DTHUPD(0)| PWM_DTUPD_DTLUPD(555);
          case 1: //ppn = 110 => 012
            //PWM->PWM_CH_NUM[0].PWM_CDTYUPD = p;
            PWM->PWM_CH_NUM[1].PWM_CDTYUPD = p;
            //PWM->PWM_CH_NUM[2].PWM_CDTYUPD = n;
          case 2: //npn = 010 => 012
            PWM->PWM_CH_NUM[0].PWM_CDTYUPD = n;
            //PWM->PWM_CH_NUM[1].PWM_CDTYUPD = p;
          case 3: //npp = 011 => 012
            //PWM->PWM_CH_NUM[0].PWM_CDTYUPD = n;
            PWM->PWM_CH_NUM[2].PWM_CDTYUPD = p;
          case 4: //nnp = 001 => 012
            //PWM->PWM_CH_NUM[2].PWM_CDTYUPD = p;
          case 5: //pnp = 101 => 012
            //PWM->PWM_CH_NUM[1].PWM_CDTYUPD = n;
          default:
        count = (count + 1) % 6;
I also tried setting the update unlock bit in the ‘update_Duty_Cycle().’
PWM->PWM_SCUC = PWM_SCUC_UPDULOCK;
But that still doesn’t work.
You're right, the dead-time insertion isn't working.
I believe this is because in your implementation you're using 0% and 100% duty-cycle periods and on the high side it's not possible to add dead-time to a signal whose duty-cycle is already maxed out at 100%. On the Due's SAM3X8E microcontroller the low side doesn't work either, although strangely it does on the Arduino Zero's SAMD21.
Anyway, I think a new strategy is required. I'm looking at using the Due's PWM controller output override, together the compare interrupt. Initial tests look quite promising, I'll get back to you tomorrow.
I finally got it working.
Instead of using dead-time insertion, the code enables PWM channels 3 and 4 and uses their compare match interrupts to specify a point along the timer cycle, at which to enable/disable the override of the PWM outputs. Channel 3 determines the low side dead-time, channel 4 the high.
Here's the output, for comparison purposes PWML0 (yellow) and its complement PWMH0 (light blue) have output override disabled, where as PWML1 (pink) and its complement PWMH1 (dark blue) it's enabled.
I modified your code, output override is enabled for all channels:
volatile float CPRDV = 0;
int divA = 42;
  PWM->PWM_SCM |= PWM_SCM_SYNC0 | PWM_SCM_SYNC1 | PWM_SCM_SYNC2 | PWM_SCM_SYNC3 | PWM_SCM_SYNC4;      // Synchronizing of Channels 0, 1, 2, 3 & 4
  calcCPRDV();
  PWM->PWM_CH_NUM[0].PWM_CPRD = CPRDV;                // Channel 0 Period f = 2MHz/(CPRD)= 100Hz = 0.01s |CPRD = 2MHz/f
  PWM->PWM_CH_NUM[0].PWM_CMR = PWM_CMR_CPRE_CLKA;     // Period is left aligned,clock source is CLKA on Channel 0
  // PWM Channels 3 and 4 set the low and high side dead-time respectively
  PWM->PWM_CMP[3].PWM_CMPV = 2000;                                  // Set the channel 3 compare value to 2000
  PWM->PWM_CMP[3].PWM_CMPM = PWM_CMPM_CEN;                          // Enable channel 3 compare match
  PWM->PWM_CMP[4].PWM_CMPV = 2000;                                  // Set the channel 4 compare value to 2000
  PWM->PWM_CMP[4].PWM_CMPM = PWM_CMPM_CEN;                          // Enable channel 4 compare match
  PWM->PWM_IER2 = PWM_IER2_CMPM3 | PWM_IER2_CMPM4;                  // Enable interrupt on PWM channel 0 triggered at end of PWM period
  PWM->PWM_ENA = PWM_ENA_CHID0;                                     // Enable synchronous PWM on all channels
void loop(){}
    update_Duty_Cycle(count);            // Update the duty cycles
  uint32_t status = PWM->PWM_ISR2;
  if (status & PWM_IER2_CMPM3)           // Check if a compare condition on channel 3 has occured
    switch (count)
      case 1:
        PWM->PWM_OSC = PWM_OSC_OSCL1;    // Disable channel 1 low side override
      case 3:
        PWM->PWM_OSC = PWM_OSC_OSCL2;    // Disable channel 2 low side override
      case 5:
        PWM->PWM_OSC = PWM_OSC_OSCL0;    // Disable channel 0 low side override
      default:
  if (status & PWM_IER2_CMPM4)         // Check if a compare condition on channel 4 has occured
    switch (count)
      case 0:
        PWM->PWM_OSC = PWM_OSC_OSCH2;     // Disable channel 2 high side override
      case 2:
        PWM->PWM_OSC = PWM_OSC_OSCH0;     // Disable channel 0 high side override
      case 4:
        PWM->PWM_OSC = PWM_OSC_OSCH1;     // Disable channel 1 high side override
      default:
void calcCPRDV ()
void update_Duty_Cycle(byte count)
  if(stateCount < 6)
    stateCount++;
    static uint32_t p = CPRDV;
    static uint32_t n = 0;
    switch(count)
        PWM->PWM_OSS = PWM_OSS_OSSH2;               // Override the channel 2 high side output to 0V
        PWM->PWM_CH_NUM[0].PWM_CDTY = p;
        PWM->PWM_CH_NUM[1].PWM_CDTY = n;
        PWM->PWM_CH_NUM[2].PWM_CDTY = n;
        PWM->PWM_OSS = PWM_OSS_OSSL1;               // Override the channel 1 low side output to 0V
        PWM->PWM_CH_NUM[1].PWM_CDTY = p;
        PWM->PWM_OSS = PWM_OSS_OSSH0;               // Override the channel 0 high side output to 0V
        PWM->PWM_CH_NUM[0].PWM_CDTY = n;
        PWM->PWM_OSS = PWM_OSS_OSSL2;               // Override the channel 2 low side output to 0V
        PWM->PWM_CH_NUM[2].PWM_CDTY = p;
        PWM->PWM_OSS = PWM_OSS_OSSH1;               // Override the channel 1 high side output to 0V
        PWM->PWM_OSS = PWM_OSS_OSSL0;              // Override the channel 0 low side output to 0V
      default:
Thanks so much! you have been a great help to me. I'll test it in the lab today.
