Hello everyone!
I'm building a visible light communication project. The main idea is to use:
- Arduino + DC source + Bias Tee + LED to modulate data and send it through LED as modulated on/off.
- Arduino + photodetector to receive modulated data and processing to action some artifacts.
The general scheme goes like this:
I have successfully created a demo using a signal generator instead of Arduino. I use a sine/square wave, send it to Bias Tee, add 12v and everything is working well. I got a signal raised above 0v.
Now I have to replace the signal generator with Arduino and use it as a data source. The code isn't a big deal at the moment because I'm OK with sending only pulses at the moment.
I understand that Bias Tee blocks DC current as input due to capacitor. So, I'm trying to generate an AC signal with Arduino but also, I understand that Arduino can't generate negative (or change direction) of current.
What options do I have to generate an AC signal from Arduino to pass through Bias Tee with data?
