why not have the DUE generate the 50Hz timing signal and sync to the incoming signal, when possible. In other words if the external signal does not come in the Due still does its 50Hz thing.
The Due can multitask. I used uMT as an OS for multitasking on the Due. It works very well and is a great intro to using freeRTOS.
here is a copy of my use of uMT on the DUE to multi-task.
#include <uMT.h>
#include <Wire.h>
#include "TFMini.h"
#include <Servo.h>
#include <SimpleDHT.h>
// scl pin 5, sda pin 4, vcc 3.3
// temperature, pressure, altitude, sealevelpressure
#define BMP085_ADDRESS 0x77 // I2C address of BMP085
#define BMP_Interval 65503
const unsigned char OSS = 0; // Oversampling Setting
// Calibration values
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
// b5 is calculated in bmp085GetTemperature(...), this variable is also used in bmp085GetPressure(...)
// so ...Temperature(...) must be called before ...Pressure(...).
long b5;
const String sSeperator = " ";
Servo ServoLIDAR;
#define ServoLIDARPosit 1450
#define byteServo_LIDAR_Pin 11
String sA = "";
//X Axis servo
Servo X_Axis;
#define byteXaxisServoPin 9
#define iX_Posit90 1538 //using writeMicroseconds
int iX_HowMuch = iX_Posit90;
//Y Axis servo
Servo Y_Axis;
#define byteYaxisServoPin 10
#define iY_Posit90 1492 //using writeMicroseconds
int iY_HowMuch = iY_Posit90;
TFMini tfmini;
// unsigned long lPreviousLIDAR_SequenceMillis = 0;
#define lLIDAR_SequenceInterval 50 // milliseconds
// 25mS is 40Hz
// 33mS ~30Hz
// 50mS 20Hz
// bool bBlankLIDAR = false;
#define byteUnoDataReady 22
// unsigned long lCurrentMillis = 0;
//microwave motion detector= iMW
#define MWM_PINin 34
#define MWM_PINout 36
// #define lLEDRateInterval 125 //milliseconds, second
// unsigned long lPreviousLED_BlinkMillis = 0;
// bool bLedOnOff = false;
String sMessageToSend;
String sPi;
// bool bRcveDone = false;
// for DHT11,
// VCC: 5V or 3V
// GND: GND
// DATA: 2
#define pinDHT11 2
SimpleDHT11 dht11(pinDHT11);
#define iDHT_Interval 60503
#define iDoVolts_Interval 45007
#define MINservo 1000
#define MAXservo 2000
#define SerialBaudRate 9600
#define Serial2BaudRate 115200
#define StringBufferSize 50
// bool bTask2Started = false;
#define EVENT_A 0x0001
TaskId_t iEvtID_A;
#define EVENT_B 0x0002
TaskId_t iEvtID_B;
#define EVENT_C 0x0003
TaskId_t iEvtID_C;
#define EVENT_D 0x0004
TaskId_t iEvtID_D;
#define EVENT_E 0x0005
TaskId_t iEvtID_E;
#define EVENT_F 0x0006
TaskId_t iEvtID_F;
#define SEM_ID_01 1 // Semaphore id
#define SEM_ID_02 2 // Semaphore id
#define SEM_ID_03 3 // Semaphore id
#define SEM_ID_04 4 // Semaphore id
// #define TIMEOUT_A
Stream* stream2Ptr;
pinMode(40, OUTPUT);
digitalWrite( 40, LOW );
pinMode(byteUnoDataReady, OUTPUT);//setup interrupt pin as output
digitalWrite(byteUnoDataReady, LOW);//set state initial
Serial1.begin(TFMINI_BAUDRATE);
// Initialize the TFMini LIDAR
tfmini.begin(&Serial1);
// Initialize single measurement mode with external trigger
tfmini.setSingleScanMode();
Serial2.begin( Serial2BaudRate );
stream2Ptr = &Serial2;
pinMode(MWM_PINin, INPUT);
pinMode(MWM_PINout, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);//blink LED at pin 13
analogReadResolution( 12 );
ServoLIDAR.attach( byteServo_LIDAR_Pin, MINservo, MAXservo ); // attaches the servo pin to the servo object
ServoLIDAR.writeMicroseconds(ServoLIDARPosit);//sets initial posit
X_Axis.attach( byteXaxisServoPin, MINservo, MAXservo );
X_Axis.writeMicroseconds( iX_Posit90 );
Y_Axis.attach( byteYaxisServoPin, MINservo, MAXservo );
Y_Axis.writeMicroseconds( iY_Posit90 );
Serial.begin(SerialBaudRate);
// allocate a buffer in memory for these strings
sMessageToSend.reserve( StringBufferSize );
sPi.reserve( StringBufferSize );
Wire.begin();
bmp085Calibration();
ADC->ADC_MR |= 0x80; //set free running mode on ADC
REG_ADC_MR = (REG_ADC_MR & 0xFFF0FFFF) | 0x00020000; // adc start up value
// ADC->ADC_CHER = 0x80; //enable ADC on pin A0
Kernel.Kn_Start();
} // setup()
// if ( !bTask2Started )
Errno_t error;
TaskId_t fC_P;
// fCheck_Pressure
error = Kernel.Tk_CreateTask(fCheck_Pressure, fC_P);
if ( error != E_SUCCESS )
fKernalError( "fCheck_Pressure", error );
// bTask2Started = !bTask2Started;
Kernel.Tk_StartTask(fC_P);
// fCheck_TH
TaskId_t fC_TH;
error = Kernel.Tk_CreateTask(fCheck_TH, fC_TH);
fKernalError( "fCheck_TH", error );
Kernel.Tk_StartTask( fC_TH ) ;
// fCheckInputVoltage
TaskId_t fDoVolts;
error = Kernel.Tk_CreateTask( fCheckInputVoltage, fDoVolts );
fKernalError( "fCheckInputVoltage", error );
Kernel.Tk_StartTask( fDoVolts ) ;
// fDoLIDAR
TaskId_t fLIDAR;
error = Kernel.Tk_CreateTask( fDoLIDAR, fLIDAR );
fKernalError( "fDoLIDAR", error );
Kernel.Tk_StartTask( fLIDAR ) ;
// fReadSerial
error = Kernel.Tk_CreateTask( fReadSerial, iEvtID_A );
Kernel.Tk_StartTask( iEvtID_A );
// fDO_bRcveDone
error = Kernel.Tk_CreateTask( fDO_bRcveDone, iEvtID_B );
Kernel.Tk_StartTask( iEvtID_B );
// fTweakServoX
error = Kernel.Tk_CreateTask( fTweakServoX, iEvtID_C );
Kernel.Tk_StartTask( iEvtID_C );
// fTweakServoY
error = Kernel.Tk_CreateTask( fTweakServoY, iEvtID_D );
Kernel.Tk_StartTask( iEvtID_D );
// fLIDAR_ServoAspectChange
error = Kernel.Tk_CreateTask( fLIDAR_ServoAspectChange, iEvtID_E );
Kernel.Sm_Release( SEM_ID_02 ); // release a single SEMAPHORE token
Kernel.Sm_Release( SEM_ID_03 );
Kernel.Tk_StartTask( iEvtID_E );
// fSendOut_SEMAPHORE
error = Kernel.Tk_CreateTask( fSendOut_SEMAPHORE, iEvtID_F );
Kernel.Sm_Release( SEM_ID_01 ); // release a single SEMAPHORE token
Kernel.Tk_StartTask( iEvtID_F );
for ( ;; )
if ( stream2Ptr->available() >= 1 )
// if (Serial2.available() >= 1)
Kernel.Ev_Send(iEvtID_A, EVENT_A);
Kernel.Sm_Claim(SEM_ID_04, uMT_WAIT); // stop and wait for serial to be received and release of SEMAPHORE token
} // serial available
Kernel.Tk_Yield();
} // loop
void fKernalError(String sTask, unsigned error)
Serial.print( " Tk_CreateTask(): " + sTask + " Failure! - returned " );
Serial.println( error );
Serial.flush();
Kernel.isr_Kn_FatalError();
} // void fKernalError()
// digitalWriteDirect / digitalReadDirect
// example: digitalWriteDirect(13, HIGH)
inline void digitalWriteDirect(int pin, boolean val)
if (val) g_APinDescription[pin].pPort -> PIO_SODR = g_APinDescription[pin].ulPin;
else g_APinDescription[pin].pPort -> PIO_CODR = g_APinDescription[pin].ulPin;
// example: digitalReadDirect(12)
inline int digitalReadDirect(int pin)
return !!(g_APinDescription[pin].pPort -> PIO_PDSR & g_APinDescription[pin].ulPin);
void fDoLIDAR()
long iLIDAR_Distance = 0;
long iLIDAR_Strength = 0;
String sMsgToSend;
String s_cm = "cm ";
sMsgToSend.reserve( 16 );
while (1)
Kernel.Tm_WakeupAfter( lLIDAR_SequenceInterval ); // Wake up after ... milliseconds
Kernel.Sm_Claim(SEM_ID_02, uMT_WAIT); // // stop lidar servo
Kernel.Sm_Claim(SEM_ID_03, uMT_WAIT); // stop x y servo
// if ( !bBlankLIDAR )
if ( digitalReadDirect( MWM_PINin ) )
// if ( digitalRead( MWM_PINin ) == 1 )
digitalWriteDirect( MWM_PINout, HIGH );
tfmini.externalTrigger();
iLIDAR_Distance = tfmini.getDistance();
iLIDAR_Strength = tfmini.getRecentSignalStrength();
if (iLIDAR_Distance < 600)
// Serial.println( "TF Mini distance " + String(iLIDAR_Distance) + s_cm + " strength " + String(iLIDAR_Strength ) );
// Serial.flush();
sMsgToSend.concat( s_cm + String(iLIDAR_Distance) + " " + String(iLIDAR_Strength ) );
Kernel.Sm_Claim(SEM_ID_01, uMT_WAIT); // // claim a single SEMAPHORE token
sMessageToSend = sMsgToSend;
Kernel.Ev_Send(iEvtID_F, EVENT_F); // trigger fSendOut_SEMAPHORE + consume a single SEMAPHORE token
sMsgToSend = "";
digitalWriteDirect( MWM_PINout, LOW );
// bmp085 functions
// Calculate pressure given up
// calibration values must be known
// b5 is also required so bmp085GetTemperature(...) must be called first.
// Value returned will be pressure in units of Pa.
long bmp085GetPressure(unsigned long up)
long x1, x2, x3, b3, b6, p;
unsigned long b4, b7;
b6 = b5 - 4000;
// Calculate B3
x1 = (b2 * (b6 * b6) >> 12) >> 11;
x2 = (ac2 * b6) >> 11;
x3 = x1 + x2;
b3 = (((((long)ac1) * 4 + x3) << OSS) + 2) >> 2;
// Calculate B4
x1 = (ac3 * b6) >> 13;
x2 = (b1 * ((b6 * b6) >> 12)) >> 16;
x3 = ((x1 + x2) + 2) >> 2;
b4 = (ac4 * (unsigned long)(x3 + 32768)) >> 15;
b7 = ((unsigned long)(up - b3) * (50000 >> OSS));
if (b7 < 0x80000000)
p = (b7 << 1) / b4;
p = (b7 / b4) << 1;
x1 = (p >> 8) * (p >> 8);
x1 = (x1 * 3038) >> 16;
x2 = (-7357 * p) >> 16;
p += (x1 + x2 + 3791) >> 4;
return p;
// Calculate temperature given ut.
// Value returned will be in units of 0.1 deg C
short bmp085GetTemperature(unsigned int ut)
long x1, x2;
x1 = (((long)ut - (long)ac6) * (long)ac5) >> 15;
x2 = ((long)mc << 11) / (x1 + md);
b5 = x1 + x2;
return ((b5 + 8) >> 4);
// Read the uncompensated pressure value
unsigned long bmp085ReadUP()
unsigned char msb, lsb, xlsb;
unsigned long up = 0;
// Write 0x34+(OSS<<6) into register 0xF4
// Request a pressure reading w/ oversampling setting
Wire.beginTransmission(BMP085_ADDRESS);
Wire.write(0xF4);
Wire.write(0x4 + (OSS << 6));
Wire.endTransmission();
// Wait for conversion, delay time dependent on OSS
// delay(2 + (3 << OSS));
Kernel.Tm_WakeupAfter( 2 + (3 << OSS) );
// Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
Wire.write(0xF6);
Wire.requestFrom(BMP085_ADDRESS, 3);
// Wait for data to become available
while (Wire.available() < 3)
msb = Wire.read();
lsb = Wire.read();
xlsb = Wire.read();
up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8 - OSS);
return up;
// Read the uncompensated temperature value
unsigned int bmp085ReadUT()
unsigned int ut;
// Write 0x2E into Register 0xF4
// This requests a temperature reading
Wire.write(0xF4);
Wire.write(0x2E);
// Wait at least 4.5ms
Kernel.Tm_WakeupAfter( 5 );
// delay(5);
// Read two bytes from registers 0xF6 and 0xF7
ut = bmp085ReadInt(0xF6);
return ut;
// Stores all of the bmp085's calibration values into global variables
// Calibration values are required to calculate temp and pressure
// This function should be called at the beginning of the program
void bmp085Calibration()
ac1 = bmp085ReadInt(0xAA);
ac2 = bmp085ReadInt(0xAC);
ac3 = bmp085ReadInt(0xAE);
ac4 = bmp085ReadInt(0xB0);
ac5 = bmp085ReadInt(0xB2);
ac6 = bmp085ReadInt(0xB4);
b1 = bmp085ReadInt(0xB6);
b2 = bmp085ReadInt(0xB8);
mb = bmp085ReadInt(0xBA);
mc = bmp085ReadInt(0xBC);
md = bmp085ReadInt(0xBE);
// Read 2 bytes from the BMP085
// First byte will be from 'address'
// Second byte will be from 'address'+1
int bmp085ReadInt(unsigned char address)
unsigned char msb, lsb;
Wire.write(address);
Wire.requestFrom(BMP085_ADDRESS, 2);
while (Wire.available() < 2);
msb = Wire.read();
lsb = Wire.read();
return (int) msb << 8 | lsb;
// Read 1 byte from the BMP085 at 'address'
char bmp085Read(unsigned char address)
unsigned char data;
Wire.requestFrom(BMP085_ADDRESS, 1);
while (!Wire.available())
return Wire.read();
void fCheck_Pressure()
Errno_t error;
// TimerId_t TmId;
String sMsgToSend;
sMsgToSend.reserve( StringBufferSize );
short bmp_temperature;
long bmp_pressure;
// float bmp_altitude;
//Serial.println( "do fCheck_Pressure" );
//Serial.flush();
while (1)
error = Kernel.Tm_WakeupAfter( BMP_Interval ); // Wake up after ... seconds
if (error != E_SUCCESS)
Serial.print(F(" WakeupAfter(): Tm_WakeupAfter() Failure! - returned "));
Serial.print((unsigned)error);
Serial.flush();
if ( digitalReadDirect( MWM_PINin ) == 0 )
sMsgToSend = "Pa ";
// Serial.println( "do fCheck_Pressure3" );
// Serial.flush();
bmp_temperature = bmp085GetTemperature(bmp085ReadUT());
bmp_pressure = bmp085GetPressure(bmp085ReadUP());
// sMsgToSend.concat( String(bmp_temperature) + sSeperator );
sMsgToSend.concat( String(bmp_pressure) + sSeperator );
// sMsgToSend.concat( String(bmp_altitude) + sSeperator );
// Serial.println( sMsgToSend );
// Serial.flush();
sMsgToSend = "";
// // bTask2Started = false;
void fCheck_TH()
// TimerId_t TmId1;
String sMsgToSend;
byte temperature = 0;
byte humidity = 0;
String sTH = "TH ";
while (1)
Kernel.Tm_WakeupAfter( iDHT_Interval ); // Wake up after ... seconds
dht11.read(&temperature, &humidity, NULL);
sMsgToSend = sTH;
sMsgToSend.concat( String(temperature) + sSeperator + String(humidity) );
// Serial.flush();
sMsgToSend = "";
} // while (1)
void fDO_bRcveDone()
String sAspectCng = "AspectCng";
String s_gX = "gX";
String s_gY = "gY";
Event_t eventoutB;
while (1)
Kernel.Ev_Receive(EVENT_B, uMT_ANY, &eventoutB);
digitalWriteDirect( 40, HIGH );
sPi.replace( "/", " " );
// sPi.trim();
// Serial.println(sPi + " bRcveDone" );
// Serial.flush();
if (sPi.substring(0, 9) == sAspectCng)
// Serial.println(sPi + " rcvd" );
sA = sPi.substring(9);
Kernel.Ev_Send(iEvtID_E, EVENT_E);
// Serial.println("AspectString " + sA );
// Serial.flush();
// Serial.println( sPi.substring(0, 2) );
if ( sPi.substring(0, 2) == s_gX )
// Serial.println(sPi);
// Serial.flush();
// stop lidar if lidar has token do not wait for freed token skip torque attempt
if ( Kernel.Sm_Claim(SEM_ID_03, uMT_NOWAIT) != E_WOULD_BLOCK )
iX_HowMuch = sPi.substring(3).toInt();
Kernel.Ev_Send(iEvtID_C, EVENT_C);
if ( sPi.substring(0, 2) == s_gY )
// Serial.flush();
iY_HowMuch = sPi.substring(3).toInt();
Kernel.Ev_Send(iEvtID_D, EVENT_D);
sPi = "";
digitalWriteDirect( 40, LOW );
void fReadSerial()
Event_t eventoutA;
char OneChar;
while (1)
// Event_t eventoutA;
Kernel.Ev_Receive(EVENT_A, uMT_ANY, &eventoutA);
while ( stream2Ptr->available() )
OneChar = stream2Ptr->read();
if ( (OneChar != '\n') )
//Serial.println(sPi);
sPi.concat( OneChar );
// Serial.println(sPi + " char" );
// Serial.flush();
} // if ( (OneChar != '\n') )
Kernel.Ev_Send(iEvtID_B, EVENT_B); // trigger fDO_bRcveDone
// bRcveDone = true;
// Serial.println( "bRcveDone set true" );
Serial.flush();
} // if ( (chrOne != '\n') ) else
} // while ( Serial2.available() )
Kernel.Sm_Release( SEM_ID_04); // release serial avaible trigger in loop
} // while (1)
1000 u sec to 2000 u sec limit = 90 degrees of travel +/-45 deg
1K = 45 to 2K = 135
void fTweakServoX()
Event_t eventoutC;
while (1)
Kernel.Ev_Receive(EVENT_C, uMT_ANY, &eventoutC);
X_Axis.writeMicroseconds( iX_HowMuch );
void fTweakServoY()
Event_t eventoutD;
while (1)
Kernel.Ev_Receive(EVENT_D, uMT_ANY, &eventoutD);
// Serial.println( "iY_HowMuch = " + String(iY_HowMuch) );
Y_Axis.writeMicroseconds( iY_HowMuch );
// send data to RPi
void fSendOut_SEMAPHORE()
Event_t eventoutF;
while (1)
Kernel.Ev_Receive(EVENT_F, uMT_ANY, &eventoutF);
// Serial.println("fSendOut_SEMAPHORE 0 " + sMessageToSend );
// Serial1.flush();
if ( sMessageToSend.length() >= 2 )
// Serial.println("fSendOut_SEMAPHORE 1 " + sMessageToSend );
// Serial.flush();
stream2Ptr->println( sMessageToSend );
digitalWrite(byteUnoDataReady, HIGH);//TRIGGER RPi3 to read data
// delay( .05 );
Kernel.Tm_WakeupAfter( 50 );
// Serial.println( sMessageToSend.length() );
// Serial.println("fSendOut_SEMAPHORE " + sMessageToSend );
// Serial.flush();
digitalWrite(byteUnoDataReady, LOW);//reset
sMessageToSend = "";
void fLIDAR_ServoAspectChange()
char fltBuff[32];
String sAspectComplete = "AspectComplete";
Event_t eventoutE;
String sMsgToSend;
while (1)
Kernel.Ev_Receive(EVENT_E, uMT_ANY, &eventoutE);
Kernel.Sm_Claim(SEM_ID_02, uMT_WAIT); // // claim a single SEMAPHORE token.
if ( sA.length() < 8 )
// bBlankLIDAR = true;
sA.toCharArray(fltBuff, sizeof(fltBuff));
float fltAspect = atof(fltBuff);
if (fltAspect > 900.00f)
// Serial.println("AspectString " + String(sA));
// Serial.flush();
ServoLIDAR.writeMicroseconds(fltAspect);
//delay(20);
// Serial.println( "AspectComplete " + sA );
// Serial.flush();
Serial.println("AspectString reject " + String(sA));
// Serial.println( "fLIDAR_ServoAspectChange " + sMessageToSend );
// Serial.flush();
sMsgToSend = sAspectComplete;
// bBlankLIDAR = false;
void fCheckInputVoltage()
String sMsgToSend;
String s_Volts = "VOLT ";
while (1)
Kernel.Tm_WakeupAfter( iDoVolts_Interval ); // Wake up after ... seconds
// Serial.println( "dovolt awake1" );
// Serial.flush();
sMsgToSend = s_Volts;
sMsgToSend.concat(String(analogRead(A0)));
// Serial.println( "fCheckInputVoltage" + sMsgToSend );
// Serial.flush();
sMsgToSend = "";
// Kernel.Sm_Release(SEM_ID_02);
Hope it gives you ideas.
uMT has a users manual.
