My laser harp has 2 buttons to control parameters - one button selects the parameter and the other selects the value. It works ok, but I found I had to put 1 second delays after pushing buttons to deal with multiple-presses and debouncing etc...
Is there a library, or preferred way to deal with buttons?
As what I've done is very clunky...
One second is a bit long - I usually use 20 -> 25ms for debounce time.
How you implement this depends on how you structure your application. In my case, I usually have a loop that runs periodically. On the Arduino, I've been using 1ms as its easy to generate. Then I would use a state machine and a down counter for the buttons.
If you really want to fully understand debouncing and the various solutions, the ultimate reference is http://www.ganssle.com/debouncing.pdf0 . It covers almost every aspect. If you just want some quick ideas, skip down to p17 where it talks about software solutions.
50ms is usually "fast enough" for user input.
HTH,
PS: a general purpose switch debouncing routine would make an excellent playground article. [hint, hint]
