I have my code doing almost everything I want it to do, yet I think the debounce of a button is not working. I have looked up some ways to do this properly online and I was thinking I figured it out. Sometimes it will still double click!!! At least its not tripple clicking often anymore. If anyone has some ideas on how to make it better i would love to hear about it ]
Heres the function with the button
void savecolor()
int fadeChooseState = digitalRead(fadechoose);
if (fadeChooseState != lastFadeChooseState)
if ( (millis() - lastDebounceTime) > debounceDelay)
if (fadeChooseState == LOW)
delay (200);
if (fadeChooseCounter < 10)
fadeChooseCounter++;
lastDebounceTime = millis();
place[fadeChooseCounter][0] = analogRead(rpot)/4;
place[fadeChooseCounter][1] = analogRead(gpot)/4;
place[fadeChooseCounter][2] = analogRead(bpot)/4;
redVal = place[fadeChooseCounter][0];
grnVal = place[fadeChooseCounter][1];
bluVal = place[fadeChooseCounter][2];
lastFadeChooseState = fadeChooseState;
Serial.print("Fade choose state");
Serial.println(fadeChooseCounter);
Serial.print("red (1)");
Serial.print(place[0][0]);
Serial.print("red (2)");
Serial.print(place[1][0]);
Serial.print("red(3)");
Serial.print(place[2][0]);
heres the full code
//led pins
const byte red =11;
const byte green =9;
const byte blue =10;
//potentiometer pins
const int rpot =A3;
const int gpot =A4;
const int bpot =A5;
//potentiometer values
int rpotval = 0;
int gpotval = 0;
int bpotval = 0;
//buttons choose
int fadeChooseCounter = 0;
int lastFadeChooseCounter = 0;
int lastFadeChooseState = 0;
// buttons display
int fadeon =2;
int fadechoose =3;
//packages the values
int rgb[3]={
0};
int place[100][3]={
0 }
int column = 0;
int fadeval1;
int fadeval2;
int fadeval3;
// saved values
int loopCount = 60;
int black[3] = {
0, 0, 0};
int redVal= black[0];
int grnVal= black[1];
int bluVal= black[2];
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
int rval1;
int gval1;
int bval1;
//declair pins functions
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
pinMode(fadechoose, INPUT);
pinMode(fadeon, INPUT);
void savecolor();
void displaycolors();
void potfun();
//runs the functions
savecolor();
displaycolors();
long lastDebounceTime = 0;
long debounceDelay = 50;
//stores the color in memory
void savecolor()
delay (200);
// fades stored values
int fadeOnState = digitalRead(fadeon);
if(fadeOnState == LOW)
int i;
for ( i = 0; i < fadeChooseCounter; i++)
crossFade (place[i]);
Serial.print("crossFade");
Serial.print(place[i][0]);
else if (fadeOnState == HIGH)
potfun();
delay(20);
void crossFade(int color[3])
int R = color[0] ;
int G = color[1] ;
int B = color[2] ;
int stepR = calculateStep(prevR, R);
int stepG = calculateStep(prevG, G);
int stepB = calculateStep(prevB, B);
if (fadeChooseCounter != lastFadeChooseCounter)
fadeChooseCounter ++;
lastFadeChooseCounter = fadeChooseCounter;
for (int i = 0; i <= 1020; i++)
redVal = calculateVal(stepR, redVal, i);
grnVal = calculateVal(stepG, grnVal, i);
bluVal = calculateVal(stepB, bluVal, i);
analogWrite(red, redVal);
analogWrite(green, grnVal);
analogWrite(blue, bluVal);
rpotval = analogRead(rpot) / 10;
if (rpotval <= 5)
delay(44);
if (rpotval <= 25)
delay(24);
else if (rpotval <= 50)
delay(12);
else if (rpotval <= 75)
delay(9);
else if (rpotval <= 100)
delay(3);
if (i == 0 or i % loopCount == 0) { // beginning, and every loopCount times
Serial.print("Loop/RGB: #");
Serial.print(i);
Serial.print(" | ");
Serial.print(redVal);
Serial.print(" / ");
Serial.print(grnVal);
Serial.println(bluVal);
prevR = redVal;
prevG = grnVal;
prevB = bluVal;
gpotval = analogRead(gpot) / 10;
if (gpotval <= 25)
delay(2000);
else if (gpotval <= 50)
else if (gpotval <= 75)
else if (gpotval <= 100)
delay(3);
int calculateStep(int prevValue, int endValue)
int step = endValue - prevValue;
if (step)
step = 1020/step;
return step;
int calculateVal(int step, int val, int i)
if ((step) && i % step == 0)
if (step > 0)
val += 1;
else if (step < 0)
val -= 1;
if (val > 255)
val = 255;
if (val < 0)
val = 0;
return val;
// reads potentiometers value and turns it from 1023 to 255
void potfun()
rpotval = analogRead(rpot)/4;
gpotval = analogRead(gpot)/4;
bpotval = analogRead(bpot)/4;
// sends values to leds so you can pick full range of colors
analogWrite(red, rpotval);
analogWrite(green, gpotval);
analogWrite(blue, bpotval);
Serial.print("redpot");
Serial.print(rpotval);
Serial.print("greenpot");
Serial.print(gpotval);
Serial.print("bluepot");
Serial.print(bpotval);
delay(3);
Moderator edit: Quote tags replace with CODE TAGS. Duplicate post deleted.
