Debounce Contact
Folks
I'm truing to get a debounce timer to work correctly.
There are 2 buttons that need the debounce , gear_R++ and gear_R-
With out the debnounce the code works fine. With not so much. Can any provide some guidance?
The code is as follows
(defined at the beginning)
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
if(digitalRead(B_R)==HIGH)
// read the state of the switch into a local variable:
int reading = digitalRead(B_G_F);
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
buttonState = reading;
if(((buttonState)==HIGH)&&(gear_R<4))
gear_R++;
else if((buttonState==HIGH)&&(gear_R>0))
gear_R--;
lastButtonState = reading;
Denouncing
https://forum.arduino.cc/index.php?topic=719995.0
Please use code tags </> for your code.
Thanks
Have a look at the code in my DebouncedSwitch library, tutorial here.
drmpf
How do i debounce 2 switch contacts?
PerryBebbington:
Denouncing
Buttons and other electro-mechanical inputs (introduction) - General Electronics - Arduino Forum
Thanks
Bad contact, you are a bad contact, consider yourself denounced . . .
:frowning:
You can install Bounce2 using the Arduino IDE's Library Manager. It works very well and includes examples.
#include <DebouncedSwitch.h>
DebouncedSwitch sw4(4); // monitor a switch on input D4
DebouncedSwitch sw5(5); // monitor a switch on input D5
  sw4.update(); // call this every loop to update switch state
  sw5.update(); // call this every loop to update switch state
// etc
  if (sw4.isDown()) {
     // do something
  if (sw5.isChanged()) { // debounced switch changed state Up or Down
    // isChanged() is only true for one loop(), cleared when update() called again
    if (!sw5.isDown()) { // switch was just released
      // do something first time switch becomes down
Simple and effective debouncing can be accomplished by scanning switches every 50ms.
Use change in state handling for your switches.
larryd:
++Karma; // LMAO ! ! !
I'm sure you look out for my silly mistakes :-[
PerryBebbington:
No, just having fun in this time of Covid.
Mistakes, I’ve made some whoppers in the past and sure more are to come :drooling_face:
