Hi! Working a project where a radio msg from a nRF24L01 will open a relay on a secound arduino with a nRF24L01.
everything works as i want, But i want some better safety feature on the relay.
I have searched and tried to implement a millis.debounce delay, on the incoming data msg but with no luck, seams to only work with a buttonState.
Why i want a timedelay on the receiver is if the nRF24L01 picks up a fast signal from a outside source it wont open the relay. I want it the check if the data msg is constant for about 0.2sec before opening the relay, if it get a signal for less then that it wont open the relay.
I saw that it is possible to have a "data validation" between the two arduino with nRF24L01 and maybe that is the way to go.
See in the code on the Receiver where i want the timedelay.
(im not to good of a programmer i understand some basics)
hope someone can help me with this or guide me in the right direction.
Kind regards// Melker S
Receiver:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <RF24_config.h>
int DataMgs[1];
RF24 radio(9,10); //Radio Input pins for nRF24L01
const uint64_t pipe = 0xE14BC8F482LL; //Transmitting Adress
int Relay1 = 5; //Relay to solinoid valve Connected to Digital pin 5
int Redled = 4; //Ledlight
int Greenled = 3; //LedLight
pinMode(Redled, OUTPUT);
pinMode(Greenled, OUTPUT);
digitalWrite(Redled, HIGH); //Red light system booting
digitalWrite(Greenled, LOW);
Serial.begin(57600); //Loading text
Serial.println("Wireless system on");
pinMode(Relay1, OUTPUT);
radio.begin(); //Start Radio
radio.openReadingPipe(1,pipe); //Open Address
radio.startListening(); //Listening after Transmitters
Serial.println("Receiver Running");
digitalWrite(Redled, LOW); //System booted and running
digitalWrite(Greenled, HIGH);
if (radio.available())
bool done = false;
while (!done)
done = radio.read(DataMgs, 1); //Reading Signal from Transmitter
Serial.print("NRF24L01 Fertilizing unit Receiveing: ");
Serial.println(DataMgs[0]);
if (DataMgs[0] == 111) //||||| HERE I WANT A DELAY||||||\\\
digitalWrite(Relay1, HIGH); //Relay ON
digitalWrite(Relay1, LOW); //Relay OFF
Serial.println("waiting for input");
delay(10);
TX:
#include <SPI.h>
#include <RF24.h>
RF24 radio(9,10); //Radio Input pins to nRF24L01
const uint64_t pipe = 0xE14BC8F482LL; //Transmitting Address
int IOinput = 2; //IO input signal to unit
int DataMsg[1]; //Data
int Greenled = 5; //LedLight
int sensorPinA0 = A0;
Serial.println("Wireless Fertilizing System KallaxFlygAB");
pinMode(2, INPUT); //IO input signal pinout on Arduino
digitalWrite(2,LOW); //Set low state on pin 2
radio.openWritingPipe(pipe); //Open Address
radio.setPALevel(RF24_PA_MAX); //Signal output power
radio.stopListening(); //Stop listning for other Transmitters
Serial.println("Transmitter Running"); //System Booted and running
// read the input on analog pin 0:
int sensorValue = analogRead(sensorPinA0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
if (sensorValue > 990){
Serial.println("IO signal Sent");
DataMsg[0] = 111;
radio.write(DataMsg, 1);
Serial.println("Ready");
DataMsg[0] = 0;
