Debounce help!
I’m making an RPM meter for my bike and so far everything is looking good except the sensor debounce.
I am planning on using a reed switch and magnet on m wheel and yadayada. BUT, whenever I activate the switch to simulate one revolution of the wheel, the value of RPM increments super fast.
I need someone to show me how I can get the arduino to wait for the sensor to go back to LOW before it can increment again.
That way no matter how long the switch is closed it only increments by 1 until it goes to LOW again.
here’s the code, I as you can see the debounce kind of thing going on here should work but it doesnt!
#include <LiquidCrystal440.h>
  //This adds the liquidCrystal capabilities to the arduino
//If you try the code and it does not work, delete these two lines above and go tools -> import library -> liquidCrystal
int changeoverTime = 1000;  //Used to determine when to change the display data
int displayCount = 0;  //Used to change between the display output
float rotationTime;  //used to hold the time of one rotation in milliseconds
float distanceTravelledPerSecond;  //this is going to be used for calculating the speed
float wheelCircumference = 159.592907;  //the unicycle wheel has a circumference of this many cm.
float RPM;  //this variable will be used to store the wheels RPM.
float speeds;  //this holds the speed of the unicycle.
float maximumSpeed; //this holds the fastest speed attained.
unsigned int distanceTravelled;  //this holds the trip distance.
unsigned int averageSpeed;  //This will hold the average speed
unsigned char revoloutions = 0;  //this holds the ammount of wheel turns. It is an unsigned char so it can hold a very big number.
unsigned char startRotation = 0;  //used to hold the millis() of the end of the last rotation
unsigned char endRotation = 0;  //used to hold the millis() of the end of the current rotation
unsigned char timeInSeconds;  //This will hold how long the program has been running for, in seconds
unsigned char timeInMilliseconds;  //This will hold how long the program has been running in milliseconds
unsigned char lastMillis;  //This will hold the last time the display data was changed
boolean reedSwitchState;  //used to hold the state of the reed switch
boolean lastReedSwitchState; //used to hold the previous state of the reed switch
const int reedSwitchPin = 5;  //The sensor is attatched to pin 5
boolean RPMstate;
boolean speedsState;
boolean maximumSpeedState;
boolean averageSpeedState;
boolean distanceTravelledState;  //These five variables will be used when reading the switches above, and will decide the variables below:
boolean showRPM = 0;  //The LCD will show the RPM if this is true
boolean showSpeeds = 0;  //The LCD will show speed if this is true
boolean showMaximumSpeeds = 0;  //the LCD will show the maximum speed if this is true
boolean showDistanceTravelled = 0;  //the LCD will show the distance travelled if this is true
boolean showAverageSpeed = 0; //The LCD will show the average speed if this is true
int test2;
int test = 4;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7,8,9,10,11,12);
//This uses all 8 of the input pins (8 bit mode) to write to the LCD faster
void DoTimeAndDistanceCalcs()
    revoloutions ++;  //add one to revoloutions - the wheel has turned round one more time
    endRotation = millis();  //keep track of the time that the rotation completed
    rotationTime = endRotation - startRotation;  //work out the time of the full rotation
    startRotation = endRotation;  //the next rotation starts when the previous one finished, so make them have both the same values
    RPM = (60000 / rotationTime);  //find out how many times you can get the rotation time inot one minute - hence working out the RPM
    distanceTravelled = revoloutions * wheelCircumference;  //the distance travelled will be the ammount of rotations * the distance travelled per rotation
    distanceTravelledPerSecond = RPM * wheelCircumference;  //speed = distance / time. The time for this is 1 second, the distance is worked out here
    distanceTravelledPerSecond = distanceTravelledPerSecond / 100;  //This gives the distance travelled per second in meters, not centimeters
    speeds = distanceTravelledPerSecond;  //The speed will be in m/s, and this is the ammount of meters travelled per second, or m/s, so it is the speed!
    if(speeds > maximumSpeed)
      maximumSpeed = speeds;  //if the new speed is faster than the maximum speed, make the current speed the new maximum speed
    timeInSeconds = millis();  //This will give the ammount of milliseconds that the program has been running for
    timeInSeconds = timeInMilliseconds / 1000;  //This will turn the time in milliseconds into the time in seconds
    averageSpeed = (distanceTravelled / timeInSeconds);  //This will give the average speed
void setup(){
  pinMode(reedSwitchPin, INPUT);  //declare the pin with the reed switch as an input
  pinMode(test, INPUT);
void loop(){
  test2 = digitalRead(test);
  //timeInMilliseconds = millis();
  displayCount = 0;
  //if((timeInMilliseconds - lastMillis) > changeoverTime){
   // displayCount ++;
   // lastMillis = millis();
   // if(displayCount == 5) displayCount = 0;
  if(displayCount == 0){  //if display Count = 0...
   showRPM = 1;  //turn showRPM to high, so the RPM will be displayed...
   showSpeeds = showMaximumSpeeds = showDistanceTravelled = showAverageSpeed = 0;  // ...and then set the rest to 0, so they will not show
  if(displayCount == 1){  //if display Count = 1...
    showSpeeds = 1;  //set the showSpeeds to high so it will display...
    showRPM = showMaximumSpeeds = showDistanceTravelled = showAverageSpeed = 0;  //...and turn the rest to low so they will not.
  if(displayCount == 2){  //if display Count = 2...
    showMaximumSpeeds = 1;  //turn maximumSpeed to high so it will display...
    showSpeeds = showRPM = showDistanceTravelled = showAverageSpeed = 0;  //...and turn the others to low so they will not.
  if(displayCount == 3){  //if display Count = 3...
    showDistanceTravelled = 1;  //turn distance travelled to high so it will display...
    showSpeeds = showRPM = showMaximumSpeeds = showAverageSpeed = 0;  //..and turn the rest to 0 so they will not.
  if(displayCount == 4){  //if display Count = 4...
    showAverageSpeed = 1;  //turn distance travelled to high so it will display...
    showSpeeds = showRPM = showMaximumSpeeds = showDistanceTravelled = 0;  //..and turn the rest to 0 so they will not.
  lastReedSwitchState = reedSwitchState;  //pass the value of reed Switch State to previous Reed Switch State
  reedSwitchState = digitalRead(reedSwitchPin);  //take a reading of the reed switch state
  if((lastReedSwitchState == LOW) && (reedSwitchState == HIGH)){  //if the reed switch is high and was previously low...
    DoTimeAndDistanceCalcs();
    lcd.clear();  //Clear the LCD to show the new results
    if(showRPM) lcd.print(RPM);  //show the RPM on the LCD
    else if(showSpeeds) lcd.print(speeds);  //show the speed on the LCD
    else if(showMaximumSpeeds) lcd.print(maximumSpeed);  //Show the maximum speed on the LCD
    else if(showDistanceTravelled) lcd.print(distanceTravelled);  //Show the distance travelled on the LCD
    else if(showAverageSpeed) lcd.print(averageSpeed);  //Show the average speed on the LCD
  Serial.println(digitalRead(reedSwitchPin));
Does this help... http://arduino.cc/forum/index.php/topic,56234.msg403239.html#msg403239
[quote author=Coding Badly link=topic=56238.msg403241#msg403241 date=1300847070] Does this help... http://arduino.cc/forum/index.php/topic,56234.msg403239.html#msg403239
[/quote]
could you explain how I can add that to my code which is here? :
