#define FALSE 0
#define TRUE 1
Instead of true and false, which are already defined?
#define COUNTDOWN_MODE 1
#define STOPWATCH_MODE 2
You really should be using an enum, called mode, with two values, countDown and stopWatch.
int digits[] = {252, 96, 218, 242, 102, 182, 190, 224, 254, 246}; // digits one to nine
Why int? Those values all are byte-sized.
unsigned long millis_start_or_reset_value = 0;
The millis in the name is useless. The value is a time. startOrResetTime makes a lot more sense, to me.
long millis_countdown_remaining=0;
boolean debounce(int button, int* buttonState, int* lastButtonState, long* lastDebounceTime) {
Pass by reference would make far more sense. The code is far simpler, too. So is the call to function.
So you can have -2134 milliseconds to count down?
int button_1_state;
int last_button_1_state = LOW;
long button_1_last_debounce_time = 0;
Why do you need to number one item?
pinMode(COUNTDOWN_STOPWATCH_SWITCH, INPUT);
So, you are not using the internal pullup resistor. How IS the switch wired?
// Clear Seven Segment Display
digitalWrite(LATCH_PIN, LOW);
shiftOut(DATA_PIN, CLOCK_PIN, LSBFIRST, 0);
digitalWrite(LATCH_PIN, HIGH);
This just screams "Make me a function". Do so. Shut it up.
millis_countdown_original_value = 28801000; // 8 hours and one second
That should be:
millis_countdown_original_value = 28801000UL; // 8 hours and one second
int reading = digitalRead(button);
if (reading != *lastButtonState) {
Now, it's probably just me, but wouldn't it make more sense to call the current button state currButtonState?
Personally, I think that is a really crappy example of debouncing, since the names don't make any damned sense, and there is nothing that makes them related, to me.
To really understand what is happening, we need to know how the switch is wired, and why you are not using the internal pullup resistor (which makes wiring the switch incredibly simple).
