Debounce in Bulk
Debouncing 14 digital pins using only 30 bytes of SRAM…
static const int NUM_PINS = 14;
uint16_t PreviousMillis;
typedef struct
  uint8_t stage;
  uint8_t previous;
debounce_t;
debounce_t debounce[NUM_PINS];
void setup( void )
  for ( uint8_t i=0; i < NUM_PINS; ++i )
    pinMode( i, INPUT_PULLUP );
    debounce[i].stage = 0xFF;
    debounce[i].previous = 0xFF;
void loop( void )
  uint16_t ThisMillis;
  ThisMillis = millis();
  if ( ThisMillis - PreviousMillis >= 3 )
      debounce[i].stage = (debounce[i].stage << 1) | digitalRead( i );
      if ( (debounce[i].stage != debounce[i].previous)
          && ((debounce[i].stage == 0x00) || (debounce[i].stage = 0xFF)) )
        // 8 bits * 3 milliseconds per bit = 24 milliseconds at the same state
        // debounce[i].stage is the state of the pushbutton
        debounce[i].previous = debounce[i].stage;
    PreviousMillis = ThisMillis;
  • pedantic mode on -
#define NUM_PINS 14
  • pedantic mode off -
:P
Also:
digitalRead( 2 )
or
digitalRead(pinNumber[i])
(but some more SRAM bytes...)
digitalRead( 2 )
...fixed.
pedantic...
...as you wish.
pedantic mode on myself on
dont' use #defines, use const ints
pedantic mode on myself off
:cold_sweat:
