This is a pretty simple question regarding the use of Debounce vs Interupts. I have just gotten started with a neopixel strip. I am trying to setup a basic program to switch between various modes of display. I have a software debounced push button that when pressed should cause the main loop to switch to the next display type.
The issue is with missing button presses. I am pretty sure the cause is the use of delay() in the chase function. When I just run the sketch and count button presses it works great.
The primary question I have is, would the use of an interupt ensure I always get the correct count, or should I simply just remove the delay and use millis() i.e. the Blink without Delay examples.
#include <avr/power.h>
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(30, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
const int pushButton = 8;
const int numButtonOptions = 6;
int currentButtonNum=0;
int buttonState = HIGH;
int lastButtonState = LOW;
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
int reading = LOW;
strip.begin();
strip.show(); // Initialize all pixels to 'off'
debounceButton();
switch (currentButtonNum) {
case 0:
//do something when var equals 1
case 1:
//do something when var equals 2
chase(0xFF0000); // Red
debounceButton();
case 2:
chase(0x00FF00); // Green
debounceButton();
default:
// if nothing else matches, do the default
// default is optional
static void chase(uint32_t c) {
for(uint16_t i=0; i<strip.numPixels()+4; i++) {
strip.setPixelColor(i , c); // Draw new pixel
strip.setPixelColor(i-4, 0); // Erase pixel a few steps back
strip.show();
delay(12);
void debounceButton()
// read the state of the switch into a local variable:
int reading = digitalRead(pushButton);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// only toggle the LED if the new button state is HIGH
if (buttonState == HIGH) {
// myledState = !myledState;
currentButtonNum++;
if(currentButtonNum > numButtonOptions)
currentButtonNum = 0;
Serial.print("Button has been pressed ");
Serial.print(currentButtonNum);
Serial.println(" Times.");
lastButtonState = reading;
