Debounce multiple switches
Hello, I need to count some pieces with limit switches on three places(mega2560).
What is recomendation for library that will fix debouncing in best way? I would like to have something call function in which I will count up or down depanding of input pin. I would use interupt pins. For example I found ezButton but as I saw it is not using interupt pins but any pin.
Thanks
Why do you want to use interrupt pins for mechanical switches? Usually that's not a good idea. How fast will your switches count pieces?
The MoToButtons class of my MobaTools library is optimized for many ( up to 32 ) switches/buttons per instance.
Maybe one, two per second. I thought to be sure to use inerupt pins that counting and other program run good.
In this case interrupts will create more problems than they solve. Polling the switches at a debouncing intervall ( maybe 20..50ms ) will do the job.
And writing non blocking code in loop() should be always done.
Do not use interrupts for slow mechanical switches.
Scan your switches every ~50ms and look for switch change in state.
Always write your sketches in a non blocking fashion.
consider
// check multiple buttons and toggle LEDs
enum { Off = HIGH, On = LOW };
byte pinsLed [] = { 10, 11, 12 };
byte pinsBut [] = { A1, A2, A3 };
#define N_BUT   sizeof(pinsBut)
byte butState [N_BUT];
int
chkButtons ()
    for (unsigned n = 0; n < sizeof(pinsBut); n++)  {
        byte but = digitalRead (pinsBut [n]);
        if (butState [n] != but)  {
            butState [n] = but;
            delay (10);     // debounce
            if (On == but)
                return n;
    return -1;
void
loop ()
    switch (chkButtons ())  {
    case 2:
        digitalWrite (pinsLed [2], ! digitalRead (pinsLed [2]));
    case 1:
        digitalWrite (pinsLed [1], ! digitalRead (pinsLed [1]));
    case 0:
        digitalWrite (pinsLed [0], ! digitalRead (pinsLed [0]));
void
setup ()
    Serial.begin (9600);
        pinMode (pinsBut [n], INPUT_PULLUP);
        butState [n] = digitalRead (pinsBut [n]);
    for (unsigned n = 0; n < sizeof(pinsLed); n++)  {
        digitalWrite (pinsLed [n], Off);
        pinMode      (pinsLed [n], OUTPUT);
But would be much more easy with a lib - and really nonblocking :wink:
#include <MobaTools.h>
MoToButtons myButtons( pinsBut, N_BUT, 20, 500 );
void setup () {
    for (unsigned n = 0; n < N_BUT; n++)  {
        digitalWrite (pinsLed [n], LOW);
void loop () {
    myButtons.processButtons();
        if ( myButtons.pressed(n) ) {
            digitalWrite (pinsLed [n], ! digitalRead (pinsLed [n]));
            Serial.print(n+1); Serial.println(". button pressed");
I am prepared for the flaming. There is also hardware debouncing. A 0.1uF ceramic cap across the switch is often all the debounce needed.
`Yes this works. Thnks. gcjr I didnt test yours soulution this is shorter :slight_smile: In your library how do you choose which button is pressed? Like if I want in down code: if input 2 count1 update for example.
byte counter = 0;
byte pinsBut [] = { 2,3,4 };
MoToButtons myButtons( pinsBut, N_BUT, 30, 500 );
void setup () {
    Serial.begin (250000);
void loop () {
         counter++;
            Serial.println(counter);
Ok, found, used part from example...
 //   for (unsigned n = 0; n < N_BUT; n++)  {
       if (PressedEvent(0)) {
         counter++;
            Serial.print(1); Serial.println(". button pressed");
       if (PressedEvent(1)) {
         counter--;
            Serial.print(2); Serial.println(". button pressed");
        if (PressedEvent(2)) {
         counter++;
            Serial.print(3); Serial.println(". button pressed");
            Serial.println("Hello");
bool PressedEvent( uint8_t buttonNbr ) {
  bool state = false;
  if ( myButtons.pressed(buttonNbr) ) {
     state = true;
  return state;
Nice.
But press event 2 should reset the counter to 0.
a7
just a test...
You don't need that function in your case. In the end it only returns the return value uf myButtons.pressed(n). So you could also use it directly:
       if (myButtons.pressed(0)) {
         counter++;
       if (myButtons.pressed(1)) {
         counter--;
        if (myButtons.pressed(2)) {
         counter++;
When I use AccelStepper for stepp motor and MobaTools for buttons it doesnt compile. When I use separate it works both.
That should not interfere with each other... :roll_eyes: Can you show the sketch? As an alternative, you could control your stepper with MobaTools too ( class MoToStepper ).
I switched to MobaTools and all is ok. Code is much more same like we discus MobaTools buttons and simple AccelSteper for stepp moving. Just for info when I compile this is the error:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from C:\Users\Milos Kovacevic\Documents\Arduino\libraries\MobaTools\src/MobaTools.h:163:0,
from C:\Users\Milos Kovacevic\Desktop\test\test.ino:7:
C:\Users\Milos Kovacevic\Desktop\test\test.ino: In function 'void setup()':
C:\Users\Milos Kovacevic\Documents\Arduino\libraries\MobaTools\src/utilities/MoToStepper.h:53:29: error: 'class AccelStepper' has no member named 'setSpeedSteps'; did you mean 'setSpeed'?
#define setMaxSpeed( speed) setSpeedSteps( speed*10 )
C:\Users\Milos Kovacevic\Desktop\test\test.ino:51:8: note: in expansion of macro 'setMaxSpeed'
m_1.setMaxSpeed(6000);
C:\Users\Milos Kovacevic\Documents\Arduino\libraries\MobaTools\src/utilities/MoToStepper.h:53:49: warning: integer overflow in expression [-Woverflow]
C:\Users\Milos Kovacevic\Documents\Arduino\libraries\MobaTools\src/utilities/MoToStepper.h:51:29: error: 'class AccelStepper' has no member named 'writeSteps'
#define moveTo writeSteps
C:\Users\Milos Kovacevic\Desktop\test\test.ino:53:8: note: in expansion of macro 'moveTo'
m_1.moveTo(2000000);
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
option enabled in File -> Preferences.
Code is:
#include <Arduino.h>
#include <AccelStepper.h>
byte counter = 0;
//Pinovi Motor_1 Traka 1
#define dirP_1 31
#define runP_1 33
#define stepP_1 13
#define motorInterfaceType 1 // Define motor interface type
AccelStepper m_1(motorInterfaceType, stepP_1, dirP_1); // Creates an instance
  // set the maximum speed, acceleration factor, initial speed and the target position
   m_1.setAcceleration(100);
         counter++;
         counter--;
       if (myButtons.pressed(3)) {
   m_1.run();
Ups :thinking: - Indeed seems you found an error with an incompatibility between AccelStepper and MobaTools if both are included. I have to have a closer look at this.
Thanks for improving MobaTools :slightly_smiling_face: :+1:
