debounce SimpleMessageSystem
Hi list,
is it possible to use Bounce Library within SimpleMessageSystem library?
best
Why? Is your simple message bouncing?
there is a by default debouncer? I have a big-enough logic circuit (CMOS) and 6 relays on it. And I have errors on the input values from arduino. Because of that I'm using the relays as an RS-FlipFlop, do you believe this may procudes this behavior?
Input from Arduino? To what?
If your messages are bouncing, then I can understand why you would want to debounce them. You can't, using the Bounce library. The Bounce library is for debouncing switches.
How that relates to SimpleMessageSystem is not at all clear.
sorry, I mean TO arduino
It seems that my pin2 is not working properly, it is an old board and not in a very good condition.
Thanks for your help
best
