const int buttonPin = 3; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
const int ledPin1 = 12; // the number of the LED pin
const int InPin = 4; // Input of DigitalPin
// Variables will change:
int ledState = LOW; // the current state of the output pin
int ledState1 = LOW; // the current state of the output pin
int lastButtonState = HIGH; // the previous reading from the input pin
int buttonState = LOW; // the current reading from the input pin
int pinState; // current state of the button
// the following variables are unsigned long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 50; // the debounce time; increase if the output flickers
//initialize serial communication at 9600 bits per second:
pinMode(buttonPin, INPUT_PULLUP);
pinMode(ledPin, OUTPUT);
pinMode(ledPin1, OUTPUT);
pinMode(InPin, INPUT_PULLUP);
// set initial LED to off
digitalWrite(ledPin, ledState);
digitalWrite(ledPin1, ledState1);
void loop () {
pinState = digitalRead(InPin);
if (pinState == LOW) {
debounce();
else if (pinState == HIGH) {
digitalWrite(ledPin, LOW);
digitalWrite(ledPin1, LOW);
debounce();
void debounce()
// read the state of the switch into a local variable:
int reading = digitalRead(buttonPin);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// only toggle the LED if the new button state is HIGH
if (buttonState == LOW) {
ledState = !ledState;
ledState1 = !ledState1;
} else
// it'll be the lastButtonState:
lastButtonState = reading;
Hello I wan't to make this code working, but then release button "InPin" and holding pressed again debounce on buttonPin starts to work only from secont time... The code should work like this: Then button InPin is pressed, led1 and led2 turn ON/OFF with debounce buttonPin. Aftere releasing InPin button leds should go off and buttonPin should not work either.
How to integrate "state change detect" for InPin ?
Just read the two pins one after the other with digitalRead on two successive lines
Then do your debounce routine on both of them. Actually I think it is a state-change you are trying to detect - rather than simply debouncing. The simplest way to avoid bounce is to have a short interval (maybe 50 millisecs) between successive reads of the same pin.
If you don't want to do a state-change test for a pin then have a variable that identifies whether to skip the test.
// C h e c k S w i t c h e s ( )
//switches are checked every debounceDelay milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void CheckSwitches()
byte thisState;
//check if this switch has changed state
thisState = digitalRead(MySwitch);
if (thisState != lastMySwitchState)
//update to the new switch state
lastMySwitchState = thisState;
//This switch position has changed, let's do some stuff
//"HIGH condition code"
//switch goes from LOW to HIGH
if (thisState == HIGH)
//Do some HIGH stuff here
//"LOW condition code"
//switch goes from HIGH to LOW
//We will toggle a LED
digitalWrite(TestLED, !digitalRead(TestLED));
} //END of MySwitch code
//similar code for other switches goes here
} //END of C h e c k S w i t c h e s ( )
int TestLED = 13;
int MySwitch = 3;
int TestLED1 = 12;
int MySwitch1 = 4;
int lastMySwitchState = 0;
int thisState;
int lastMySwitchState1 = 0;
int buttonState;
int ledState = 0;
int ledState1 = 0;
pinMode(MySwitch, INPUT_PULLUP);
pinMode(TestLED, OUTPUT);
pinMode(MySwitch1, INPUT_PULLUP);
pinMode(TestLED1, OUTPUT);
digitalWrite(TestLED, ledState);
digitalWrite(TestLED1, ledState1);
CheckSwitches();
byte thisState;
digitalWrite(ledState, LOW);
digitalWrite(ledState1, LOW);
//read the button pin, if pressed will be high, if not pressed will be low
int reading = digitalRead(MySwitch1);
//in the case that the reading is not equal to the last state set the last debounce time to current millis time
if (reading != lastMySwitchState1) {
lastMySwitchState1 = millis();
//check the difference between current time and last registered button press time, if it's greater than user defined delay then change the LED state as it's not a bounce
if ((millis()-lastDebounceTime) > debounceDelay) {
//set the LED
//save the reading. next time through the loop the state of the reading will be known as the lastButtonState
lastMySwitchState1 = reading;
Now I can’t make other button work as debounce for toggle the leds on/off. Now sometimes it works, but most of the time dont work as it should. I guess i did something wrong now.
vartaliotas:
can you clarify this?
on press of buttonA LEDs toggle
on press of buttonB What happens?
it seems you want to dis regard buttonB presses if LEDs from buttonA are lit...
Do you count this way? Uh-huh, one, two...
If you can't, or won't, use arrays, at least number ALL the variables that look like they belong together.
You read the state of one switch and store the reading in thisState. You read the state of the other switch and store it in reading. What? Consistency is a good thing.
You then compare the values in thisState and reading. They are from different switches. There is NO basis for comparing the values.
The code you adapted for debouncing switches uses three variables to determine if a switch is now pressed and was pressed n milliseconds ago. How many variables are needed to determine that? TWO!
If first switch is pressed (HIGH) second start to work as a push button (with debounce) and toogle the leds on/off. Then first pin gets released(LOW) both of leds go off and second button stops working.
I want to make a simple rear fog lamp controller for my car. But it’s harder than i thought. I just need a right example and somehow i will make it.
I think you will make this a lot easier if you start by ignoring the bounce problem and just leave a short interval between reading the switches. And then (for testing) leave a full second between each switch press.
As I said earlier, you need to read the two switches at the same time and save there states. Then you can look at the save d values and decide what to do.
If switch A is OFF then everything is turned off, regardless of switch B
And the led only toggles if switch A is ON and switch B has changed from OFF to ON - so you need a variable to record the previous value of switch B
As you are using INPUT_PULLUP your switches will read LOW when pressed.
If it's possible maybe u have an example something of this , I'am new to programing and used a lot of examples but still , I'm in a big trouble nothing else.
Ask questions if you don’t know what is happening.
// millis() returns the current run time (in ms) since the last restart.
unsigned long blockingMillis; //The time when this Timer was (re)started
unsigned long SwitchMillis; //The time when this Timer was (re)started
const unsigned long blockingInterval = 500; //1/2 second
const unsigned long debounceInterval = 50; //50ms
const byte blockingLED = 13;
const byte testLED = 8;
const byte ToggleSwitch = 2; //pushing the switch puts a LOW on the pin
byte lastToggleSwitchState; //the last state the switch was in
// s e t u p ( )
pinMode(testLED, OUTPUT);
pinMode(blockingLED, OUTPUT);
pinMode(ToggleSwitch, INPUT_PULLUP);
} //END of: s e t u p ( )
// l o o p ( )
//Some code to check for blocking code, LED should flash at 1 Hertz rate.
if (CheckTimer(blockingMillis, blockingInterval))
//Toggle the Blocking LED
digitalWrite(blockingLED, !digitalRead(blockingLED));
//Put other non-blocking stuff here
//Is it time to check the switches?
if (CheckTimer(SwitchMillis, debounceInterval))
//it is now time to read the switches
CheckSwitches();
} //END of: l o o p ( )
// F U N C T I O N S
// C h e c k T i m e r ( )
// Used when actions are needed 'after' a period of time.
boolean CheckTimer(unsigned long &lastMillis, const unsigned long Interval)
//lastMillis = the time this "timer" was (re)started
//Interval = interval/delay (mS) we are looking for.
//Is this timer enabled and has it expired?
if (millis() - lastMillis >= Interval)
lastMillis = millis();
//or use
//lastMillis += Interval; //get ready for the next iteration
//This Timer did expired
return true;
//This timer did not expire
return false;
} //END of: C h e c k T i m e r ( )
// No minimum switch press time is validated with this code (i.e. No glitch filter).
// For de-bounce, call this function every ~50ms.
// You add code to this function to handle all configured switches
byte switchPosition;
switchPosition = digitalRead(ToggleSwitch);
if (switchPosition != lastToggleSwitchState)
lastToggleSwitchState = switchPosition;
//"HIGH condition code" <-----<<<<<
//Switch went from LOW to HIGH
if (switchPosition == HIGH)
//"LOW condition code" <-----<<<<<
//Switch went from HIGH to LOW
digitalWrite(testLED, !digitalRead(testLED)); //toggle the testLED
} //END of: ToggleSwitch code
// Similar code for other switches goes here
} //END of: C h e c k S w i t c h e s ( )
// END OF CODE
Also, from your recent post, you /seem/ to be looking for this...
Button 1 (enable), allows you to toggle the LED states with Button 2 each time Button 2 is pressed.
-then- (not sure which of these)
When Button 1 is released, Button 2 is ignored, LlEDs stay as they are...
-or-
When Button 1 is released, Button 2 is ignored - AND the LEDs go off as well.
const byte testLED = 12;
const byte ToggleSwitch1 = 4; //pushing and holding the switch puts a LOW on the pin
const byte ToggleSwitch = 3; //pushing the switch puts a LOW on the pin
// s e t u p ( )
pinMode(ToggleSwitch1, INPUT_PULLUP); // using internal PULL UP.
// l o o p ( )
CheckSwitches();
while (digitalRead(ToggleSwitch1) == HIGH) // if Pin is LOW ToggleSwitch1 is working
if (digitalRead(ToggleSwitch1) == LOW)
digitalWrite(testLED, LOW);
digitalWrite(ToggleSwitch, HIGH);
//or use
return true;
return false;
// END OF CODE
Allright i came to this state and now it’s working as I wan’t, but I’m feeling it’s writen wrong way. Should I keep it this way or do something else ?
No need to have near-identical names - better to make them clearly descriptive (e.g. TOGGLE_ENABLE, and TOGGLE_STATE) or something... (are they really toggle switches? The operation looks like momentary buttons.)
Names are free, and descriptive names are worth their weight in electrons!
It would be nice to put your while() block in parentheses - even tho' the structure is correct, its hard to read without balanced {} around the if() {} else {} block. And the line-spacing / indentation is all over the place.
Parentheses are free too!
const byte Relay = 13; Toggle Relay
const byte testLED = 12; Toggle testLED
const byte InPin = 4; //If it pressed second button starts to work.
// s e t u p ( )
pinMode(Relay, OUTPUT);
pinMode(InPin, INPUT_PULLUP); // using internal PULL UP. If it pressed second button starts to work.
// l o o p ( )
CheckSwitches();
while (digitalRead(InPin) == HIGH) // if Pin is LOW ToggleSwitch1 is working
if (digitalRead(InPin) == LOW)
digitalWrite(Relay, LOW);
//or use
return true;
return false;
digitalWrite(Relay, !digitalRead(Relay)); //toggle Relay
// END OF CODE
Dont know why , but it’s working as it should with no glitch at this moment.
if (digitalRead(InPin) != LOW)
