debounce with seven segment and shift register not lighting correct segments.
Power_Broker:
The following should do the trick if a button press causes the input to go high. If a press causes the input to go low, then you will have to edit pines 70 and 75.
Note: The debouncing function I wrote was quick, untested, and blocking (~8ms of delay). You can change it to become non-blocking if you want.
const byte latchPin = 7;
const byte dataPin  = 4;
const byte clockPin = 8;
byte button = 13;
byte counter = 0;
byte previousState = 0;
int number_array[16] =  // 0-9 A-F
  B11111100,//0
  B01100000,//1
  B11011010,//2
  B11110010,//3
  B01100110,//4
  B10110110,//5
  B10111110,//6
  B11100000,//7
  B11111110,//8
  B11100110,//9
  B11101110,//A
  B00111110,//B
  B10011100,//C
  B01111010,//D
  B10011110,//E
  B10001110,//F
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(button, INPUT);
  debounce(button);
  writeToRegister (counter);
  debounce(button, previousState);
  if (counter < 16)
    if (!pressed)
      counter++;
    } writeToShiftRegister(counter);
  else if (counter == 16)
    counter = 0;
void writeToRegister (byte data)
  digitalWrite(latchPin, LOW);
  shiftOut(dataPin, clockPin, LSBFIRST, data);
  digitalWrite(latchPin, HIGH);
void debounce(int pin, byte &previousState)
  byte currentState = 0;
  byte pressed = 0;
currentState = digitalRead(pin);
  if(currentState && !previousState)
    while(pressed != 0xFF)
      delay(1);
      pressed = (pressed << 1) | digitalRead(pin);
previousState = currentState;
i've tried modifying it like above however, it keeps segments d-g lit but doesnt change
