Debouncing help W/ DTDP switches
Here’s a debounce script I found, but I want the “Ntoggle” to run once if the condition is correct.
int SwitchPin = 2;
int val = 0;
boolean Toggle = false;
boolean pressed = false;
int Debounce = 0;
  pinMode(SwitchPin, INPUT);
void Ntoggle()
  Serial.print("OFF ");
void toggle()
  Serial.print("ON ");
  if (digitalRead(SwitchPin)== HIGH)
   Debounce++;
   }else
    Debounce = 0;
    pressed = false;
    Toggle = false;
    if (Debounce >= 50)
      pressed = true;
    if (pressed == true && Toggle == false)
      Toggle = true;
      toggle();
     if(digitalRead(SwitchPin) < HIGH) {
      Ntoggle();
